Firefox Takes Top Marks in Browser Stability Tests
CommanderFrank
Cat Can't Scratch It
We all know everyone has their favorite browser and no amount of facts and figures are going to sway them one bit. But from time to time, it’s nice to have a reality check to see if you are on the right path. Sauce Labs is a company that tests all things Internet related and recently set the record straight on browser error rates, crashes and stability.
Of course, crash frequency isn't the only way to judge a browser. For many web developers, standards compliance, performance, and rendering quality will be just as important, if not more so.
hahaha right. And yet firefox can be entirely crashed by one bad instance of Flash. The very reason I'm using Chrome instead of Firefox. It's completely unacceptable when all my work comes to a screeching halt simply because of one fucking tab.
that is good news if the results are accurate, lately I'm finding chrome (not really crashing) but having problems loading some websites (not loading at all), even the ol google search homepage , nothing else I can do but to close everything chrome. lol, I hope the new version 29 is much more reliable
They've done a lot of work in the past year to help that. If it's still is happening to you and to the point that the entire browser is crashing it's likely a driver issue.
anyhow, the difference between stability between Firefox and Chrome in that test is 0.015% IE10 and Opera wasn't that far off either. All of them are very stable today.
Honestly haven't considered browser crashes to be big enough for any browser I use to use that factor is making a usage decision.
I use chrome mostly because it autosyncs book marks etc automatically across all my computers (helps that I have gmail account etc).
browser crashing isn't what concerns me
the ability to EASILY use ad blocking software, white/black lists, etc...
Firefox has changed since you've used it. It now allows flash to crash separately, as to not effect Firefox. Though in reality you just see Firefox frozen and you eventually get the option to disable the plugin. This is more of a Flash problem then a Firefox problem. Chrome uses it's own flash and prefers to use it's own flash over Adobe's. Cause much like Firefox, Chrome has experienced issues with flash effecting the browser.
Adobe flash is just that bad.
ever try to program in it?
/selfheadshot
That is what crashes Opera too. I've been using Opera for a while now and the amount of crashes due to Flash has been numerous. I've never had Opera crash for any other reason though and it is that Adobe Flash crapware that is the culprit. But Opera has an option to block Flash and you see an arrow to click on if you want to see the Flash content and I do use that option so Flash content never auto loads here.
Love it when this pops up and it's NOT running.
Except that's not how Firefox works... plugins like flash are in a separate process (plugin-container.exe)
If Flash screws up HORRIBLY, the worst that happens is plugin-container crashes and flash objects vanish from all tabs. Refreshing the tab will restart plugin-container and reload Flash.
Check processes in the task manager, you will only get that prompt if Firefox.exe is still listed at the time you click the shortcut.
Just because it's not on the taskbar doesn't mean it's not hung, windowless, only visible in the task manager.
Been using Firefox for so long I don't think I'm ever changing. Tried the others, claiming to be SO FAST lol.
No, no it can't unless you explicitly disable the feature they've had for years to prevent exactly that sort of scenario.
If you don't do that Flash can crash all day and it won't bring down Firefox.
Am I the only one who runs a browser without flash? It's a resource hog, a security nightmare, and primarily used to display ads. On the rare occation that I do need it I just open up a different browser, use it for whatever and then close the program.
This is the reason why I stopped using Firefox since version 3/4. Tried it again recently and it doesn't happen as often but still happens occasionally, so took it off completely. Opera FTW. :cool:
How exactly are you getting that error to occur?
I'm trying to make it happen, but I can't unless I have a batch file loop starting / killing firefox every millisecond... then it happens.
Regular usage? Not seeing it :confused:
The only time I see that as of late is on systems with older versions of flash.
It will happen sometimes if you kill Firefox using the crash reporter and don't wait for it to kill all of its processes before restarting it.
WHAT EVER. I was the biggest Firefox fanboy ever but the last year or so Flash plugins were just kicking it's ass. Bringing the whole system to it's knees because of some funky Flash problem.
Went to Chrome 3 or 4 months ago. It was a bit of a learning curve, but those Flash problems are GONE. Chrome is 99% gold. The other 1% are some sites refuse to cooperate, mainly my bill paying ones. I keep Firefox around for those.
Awesome, but missing Chrome. Never met an IE fanboy, only people who bash it without considering that maybe it's just their site or computer. That and webmasters complaining about it not treating their code very nicely...
Proud Opera user here *holds up nose and scoffs at foolish Chrome and FF fanboys* :eek:
