Firefox 4 Out Tomorrow
I'm using the RC...Liking it a lot so far. I've always been more of a Firefox fan than Chrome for whatever reason. Mostly just experience/amount of use I guess.
One of our own here @ [H] is working his ass off to make sure this release goes smoothly. ;)
I installed it, tried it, hated it, reverted back to 3.6...to each their own i guess.
I digg it however 4 took too long to bake, hell Microsoft released ie 9 before Mozilla got 4 out.
I was running chrome an the ff 4 betas for a long time, but chrome's plugin system finally matured enough for a reasonable Adblock plugin to work so I am set with chrome now. FF still requires a restart for plugins which really bothers me, they also nolong hold the speed crown so why switch back?
Had the RC running for a few days, suddenly today started crashing like crazy. Rolled back to 3.15 and its been fine.
Most odd.
FF4 does not require a restart to install plugins. They introduced a new system to allow plugins to be installed without restarting the browser.
Problem is, many plugins haven't been updated to take advantage of this feature. Complain to your favorite plugin dev, not mozilla ;)
Just installed and unfortunately none of my existing plug ins (for 3.6) were compatible with 4.0......
FF4RC2 is amazing. Can't wait until the final release!
Release version is available now and I am running it.
Only disappointment is that HW Acceleration causes font rendering to suck, so I am running with it off, to get normal font rendering. (at least on Win7).
The Beta 12, and now the RC2 that I'm using has brought me back to using Firefox. Chrome had me for about a year and a half, but Firefox has won me over again. Will be downloading the post beta release as sooon as it's available!
With four clicks you can make Firefox 4.0 look exactly like 3.6.
What exactly is your issue again?
1. No status bar by default.
2. Menu ribbon was dumb in office, why would it work here. (and when you disable the menu ribbon it uses up too much space for the old menu bar. Which in turn makes the transparent section of the browser about an inch tall and very distracting.)
3. New tab location is idiotic (i'm aware i can move it, and did).
Until I encounter a plugin that doesn't require a restart the feature doesn't really exist to me. You don't get much more major than AdBlock plus and it's companion element helper and popup window blocker.
I will wait to make sure my plugins are compatible before updating to FF4.
1) go to plugin site, right click and save.
2) use 7-zip to open the .xpi file ("open archive" menu option)
3) right click on install.rdf file in 7-zip window and select "edit"
4) change maxversion for firefox to something like 4.5
5) save in archive
6) drag and drop xpi file into firefox window
7) #winning
this works for many add-ons.
Problem is, over half my plugins were tagged as not compatible after starting up FF4. It lasted all of 3 minutes on my machine. I'm back to 3.6.
None??
I have 20+ plug ins and most of them were compatible. Still a handful of my favorites were not.
But then I went to the home pages of the incompatible ones and all but two of my plug ins had compatible versions on their home pages they weren't putting on addons.mozilla.org.
It appears that AMO has more stringent requirements now and that many extensions don't meet them, and doing a quick fix for 4.0 compatibility won't cut it. So they are hosting them on their own pages in the interim.
Of the 2 remaining extensions with no new version, I simply found a alternative that is still being actively developed. I replaced "tab aging", with "colorful tabs" and "all in one gestures" with "fire gestures".
End result everything is either updated or replaced.
If you are waiting on updates to extensions that are no longer actively developed, you will be waiting forever.
Did Mozilla ever fix the memory leak issue that has been present since the Alpha releases of the original version? If not I'm not interested in going back to FF.
Does Firefox 4 use ClearType? I have it turned off under Windows, but how can I get it turned off in Firefox?
If you turn off HW acceleration, FF will use what you system is using.
Otherwise in Win7 it will use Microsoft DirectWrite for font rendering, which is ugly IMO.
Hmm. Text still looks bad with Hardware Acceleration off. Actually it's a bit worse.
Strange. Are you running win7?
With HW Acceleration off, text is identical to FF 3.6 and Opera for me. With it on, I get fatter AA text with tight kerning running the letters together.
Left FF4 HW Accel on, Right HW Accel off (or FF 3.6/Opera)
Lot at the word "CATEGORY" up top, to see how kerning has changed. The letters are jammed together now.
Yeah, I'm not liking the text in HW accelerated FF4 either, so far.........is it a settings issue?
Rebooting after turning off Hardware Acceleration makes on-page text look normal, but text on the bookmark toolbar looks horrible.
Couple other things bothering me:
1) I customized the navigation buttons and put the Bookmarks button next to the Home/Reload/Stop buttons, but once I exit the Customize Toolbar function, the Bookmarks button disappears.
2) On the Bookmarks toolbar, Firefox appends a Bookmarks button on the far right. I can't find a way to remove it but still keep the Bookmarks toolbar. Anyone know if it's possible?
Rebooting? You mean restarting FF4, you shouldn't need to reboot.
1) I have done any button customizations. 2) perhaps that is your missing bookmark button from 1? I have not bookmark button on my bookmark toolbar.
They're different buttons. One is only a button. The other is a button with a title.
Scratch that. The Bookmarks navigation button reappears if I hide the Bookmarks toolbar. Kind of annoying. I want both, minus the Bookmarks button on the toolbar.
