Get it here: http://www.mozilla.com/en-US/
Click for full size - Uploaded with plasq's SkitchIn tabmix plus if you middle click an empty space on the bar where tabs are it would undo the last closed tab. Is there a way to add that back in?
Firefox 3.5RC x64 http://wiki.mozilla-x86-64.com/images/Firefox-3.5.en-US.win64.installer.20090630.zip
Keep in mind this is not branded as Firefox but as Shiretoko, their trunk build. But it is identical to FF. Some sites do not pick up the user agent as FF though and claim no compatibility exist, so you may have to manually install some x64 plug-ins because if they work in FF, they work on this.
I noticed that when you click and hold over a bookmark folder, there's now a delay before the folder expands. I'm too used to it expanding instantly. Not liking it.
Why do you click and hold? You know if you click, the folder opens and stays open, right? It also opens right away as opposed to having a delay. You don't need to hold in order for the folder to stay open.
My crash earlier was apparently caused by FoxyURL. I don't know how to read the details of crash reports, but I noticed foxyurl was in there somewhere.
I didn't spot anything of interest. Did you?some tweaking might be in order,
type on the address bar: "about:config"
and search something related to "menu" you might get lucky![]()
Is 3.5 compatible with noscript and adblock plugins?
Yours open just by hovering over them?
He is talking about the Bookmark menu, not the Bookmark Toolbar. Of course they just open in the Menu, its just like any other contextual menu.
Yes.
Thanks, but I found out last night that is not entirely correct. On Vista there was no issue with adblock or noscript but when I updated to 3.5 on XP FF said that it was not compatible with adblock and would disable it. Kind of odd that adblock is compatible on Vista with 3.5 but not XP.
I use Adblock plus.
HardRules said:(23) Any discussion of AD BLOCKING software or instruction for using ad blocking regarding this forum or any other discussion in general of attempting to block advertisement will result in a no questions asked permanent ban on your account. This is not done lightly, rather deliberately to deny access to those who choose to utilize this forum, but not support our sponsors. It takes money to finance the cost of bandwidth, especially a forum of this size and if you don't care enough to support us through our advertisers, then we don't need your business. This will be the only warning with no discussion.
Because Adblock is old and I don't think it's even actively developed anymore. Adblock Plus has replaced it and is fully compatible with FF3.5
Yes, this. I can't even find Adblock on the Mozilla Add-ons page anymore.
