bah - not compatible with one of my favourite add-ons - "yet another smooth scrolling"
oh well. i guess i have to wait for it to be updated![]()
Get the MR Tech Toolkit and force your add-ons to compatibility. You can do that with this add-on.
Does feel faster. I like!
My 1000HA gets killed by flash. Anyway I can customize ff? Love my netbook until I surf and a site is full of flash.
Heh, I installed RC last night. I only used it to download final.
Seems faster and I like the private browsing
You still need flash to watch videos so I don't know html5 helps.
With a stroke at the keyboard, users can erect stiff privacy barriers that will prevent their Web surfing habits from penetrating the browser history and defiling the sensitive auto-completion system with incriminating data where it might arouse the suspicions of subsequent users.
Firefox has fallen off the wagon IMO
It's super laggy and slow these days - its always freezing up for me![]()
OMG GMail loads a lot faster!!! It's like Chrome speeds now. Firefox 3.5 + Chromifox basic =![]()
Also, there's a way to install "incompatible" extensions without disabling the check. Here's how:
1. Download the extension, example linkcheker.xpi
2. Rename linchecker.xpi to linkchecker.xpi.zip
3. Open the ZIP with WinZip, drag the install.rdf file
4. Open install.rdf file with Notepad
5. Look for "<em:maxVersion>3.0.*</em:maxVersion>" and change to "<em:maxVersion>3.*.*</em:maxVersion>"
6. File > Save
7. Drag the install.rdf file back into WinZip and replace
8. Rename the ZIP back to an XPI
9. Drag XPI into Firefox 3.5
This should install and you want to test if the actual extension works.
Good callSomeone needs to cancel his Enzyte order.![]()
Why the hell did they make Ctrl+W act the same way as Alt+F4??
Absolutely kills usability.
...Changed to Noia 2.0 (eXtreme) 3.64 from Aero. I love this more than Aero...
3.5 starts up a bit faster than 3.0.11 on my computer
Thanks for posting this, the icons are great!
https://addons.mozilla.org/en-US/firefox/addon/72
To customise it with FF3.5 you need to go to your addons/themes
Right click Noia and select About...
Follow the instructions.
That is a hideous theme.. cant be serious?![]()
http://en.wikipedia.org/wiki/STS-114
Scroll to the bottom of that page and watch the video... no plugins required! Try scrolling through the video after a little downloads too... much faster than Flash. And try right clicking on the video to see what options you get.
Installed and now crashes....![]()
Guess ill be using Safari for a while.
Yes you can run 3.0.11 (for workgroups) at the same time you run 3.5 (new technology
), just install to different folders. To be safe I would use different profiles for each instance as well, otherwise they will use the same profile database files. Here is all the info you need on profiles.
Who needs themes? The anycolor addon does a good job. I can finally have a black firefox theme without annoying graphics, also the bookmark sidebar is a dark grey instead of white like it is with themes.
I see, so the "you don't need additional plugins" is somewhat misleading. Ogg is far from popular, certainly no where near flash nor mp4.
Still, a step in the right direction.
Cause personas are fugly?
