Finish this PC Build
8lack8rain
Looking to finish what I had started previously. My original Philosophy (not necessarily logical) was to get as close to 3 gigs as possible, without overclocking, with as many cores as possible, not to exceed $500 on the cpu. It's for multi use (gaming business personal). No water cooling. Linux friendly is a plus just in case I decide to go BIG NERD STYLE and do the dual boot thing. Money is not abundant and growing on trees, but luckily I have some. Not against buying used on the ebay. :cool:
Hardware purchased for current build thus far:
- Cooler Master Heatsink
- 4gb of Firestix (pc6400)
- Corsair HX620
- Raptor 150gb
Adopted Parts (from previous build):
- Logitech G5 (Mouse)
- 2 Dell 19" monitors (black)
- Win XP
Left to Obtain (NEED):
+ CPU - What would be your choice for $300. I know, I totally wimped out on the $500.
+ Case - I think I'm going with a Lian-Li (PC-7B plus II Black Aluminum ATX Mid Tower Computer Case)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112099
+ Motherboard - Do I get a non-descript intel mobo, or an outrageous board of circuits with finned copper lines, chilly mosfets, chipset cooling, with a name like THE NATAS 5000? Utilitarian and Frugal or Satanic and Beastly? Originally, I thought having two network connections would be cool. Maybe Best bang for the buck? No need for SLI. Can we keep this under $150?
+ SATA DVD burner - Anything cool with a hacked firmware or good reviews?
+ Video card - I'm trying to get a good one but am afraid of the pricetag. Are there any free video cards? Something with a gallon of memory? Please someone just lie. Like when you buy a house... no money down. I like no money down. OK $300 if you have to. But I'm going with a skunky ATI 128 (pci-e) until probably Christmas.
+ Keyboard seems to be eluding me. Maybe something to go with the case.
Top three contenders:
1. ?black aluminum?
2. http://www.newegg.com/Product/Product.aspx?Item=N82E16823114001
3. http://www.newegg.com/Product/Product.aspx?Item=N82E16823102003
(Warning) Can't buy no matter what:
1. http://www.newegg.com/Product/Product.aspx?Item=N82E16823110017
This keyboard says that I'm old and loosing my balance in the bathtub. Or I'm about to be raped and need to brace myself.
2. http://www.newegg.com/Product/Product.aspx?Item=N82E16823146004
This input device says that I have a violent tendency and plan on throwing it at you neck for a Fatality! Unless you beat me to it, then my beheaded corpse will fall into a vat of acid or a pit of spikes. No funeral. No ceremony. Just death baby! Yeah!
3. http://www.newegg.com/Product/Product.aspx?Item=N82E16823166073
This keyboard cautiously states that I can only afford half of a laptop ...currently. Please be patient damnit! Maybe the other half will come later? Or "CRAP! Who stole half of my laptop?!"
4. http://www.newegg.com/Product/Product.aspx?Item=N82E16823173011
When attacked these keys have a clever defense and folds in half, leaving the windows user to just unplug the crashed machine.
5. http://www.newegg.com/Product/Product.aspx?Item=N82E16823175002
A true man would walk in to the neighborhood pub with this one under his arm and order a cranberry juice. Now if you are EXTREME then you will do so while wearing a Hello Kitty T-shirt. Yeah, that's what I thought. No guts. Why do I even hang out with you any more?
So there. At the risk of sounding stupid, I think that finding a keyboard is a lot of damn work.
As always, I don't make a move unless it's approved ...by [H]! :p j/k. Hehe. Any suggestions would be greatly appreciated on the remaining parts.
300 - Q6600
130 - GA-P35-DS3R
47 - Tuniq Tower 120
35 - X1550
If you don't want to OC, or OC much, then the number of cores you'll be able to get to 3ghz is two. Take your pick between the Intel E6850 or the AMD Athlon 64 x2 6000+. Both of these chips run at 3ghz stock. The 6000 is half the price of the E6850 at about $150, but you can get the E6850 at around $300 w/o too much trouble. Note that the E6850 is quite superior to the 6000+ both in architecture (resulting in more ops per clock) and in OC capability. If you do decide later that you want to OC the E6850, you should get it up to 3.6ghz w/o trouble, and to 4ghz with a good air cooler.
If you don't mind OCing a bit, then buy the Core 2 Q6000 Quad for $260-$300. You should be able to OC this chip to 3ghz w/o too much trouble if you get a decent aftermarket cooler.
As for the motherboard, consider the Gigabyte DS3R if you go Intel. I haven't built an AMD machine in about three years, so I haven't been keeping up on what the best AMD boards are these days.
Good luck,
Mark.
Thanks for the replies. I really like the Intel E6850. And it seems that the Gigabyte DS3R motherboard is a solid choice as well.
"If you do decide later that you want to OC the E6850, you should get it up to 3.6ghz w/o trouble, and to 4ghz with a good air cooler." That's amazing. 4 gigs! Now that is definately an argument for overclocking. Thanks Mark. Good to know.
As for the Tuniq Tower 120, people are talking about this heatsink. I have the Freezer 7 Pro. Did I make a bad choice? I like the hide away fan for the Tuniq. Hmm...
The Freezer 7 Pro isn't as great as the Tuniq. In fact, it's just a little bit better than the stock Intel HSF. If you want a high overclock, get the Tuniq. But if you're going for a modest OC, then the AC7Pro is fine.
