Finding temps for cpu and mobo
Moe.RON
Just put together a new system for someone. He wanted dual core but didn't want to spend much and doesn't demand much performance. He plays older games mostly but wanted the ability to upgrade to SLI (whatever), and demanded intel. I picked up an pentium d 805 and a Gigabyte GA-8N-SLI mobo. I know that the pentium d's run hot and he's got a cheap case with no airflow, so I was looking for a way to monitor the temps. I tried speedfan, motherboard monitor, and even ntune to check the temps. No luck on any of those, even nmonitor detecting with the nforce 4 chipset. I just get the gpu temp for that, and speedfan sees the chipset as a nforce 2.
Any ideas?
I never had a problem with speedfan and a NF4 board. I don't think it's detecting an NF2 board, it's probably just detecting sensors similar to that of an NF2 board. I'd just run speedfan, then run Orthos and see what temp rises and that's your CPU temp even if it isn't labeled correctly (temp1, temp2, etc.).
I'm getting the 2 core temps as 0-2C, and since it's a Pentium D I know those aren't right ;)
No idea what else I can use to find these temps.
Just because it says Core temp in speedfan doesn't mean it's actually giving you the core temps ;). Are there any other temps that are given? I'm just wondering because I haven't seen too many motherboards that speedfan doesn't at least detect the motherboard CPU temp reading even if it isn't listed properly.
Yes, I got one other that was listed as I think around 34C but I assumed this was incorrect also because its a Pentium D with the stock cooler. Don't quote me on this though as I don't have the computer handy right now to check again, this is from memory.
does that number fluctuate by 10C or more when you run orthos? If it does, that's your CPU temp. 34C could be it if you're not running any programs.
