FINALLY!
y3k
I finally got a piece of hardware that is good. I've been working with old emachines motherboards and crap parts for a long time, and after getting some spare cash, I finally went out and bought a new up to date mb!
I got a Asus P5PE-VM board and a socket 775 Intel Pentium 4HT 3.06 GHz with a stick Crucial 400 DDR 512MB memory. I just chucked my old crap parts out of the window. :D I'm planning on buying another 512MB to make a dual memory set up. My hardware skills are so old, I didn't even know what DDR memory was. I am so used to SDRAM and processors with less then 1.GHz clock speed. For graphics, I'm using the intel extreme integrated graphics. The MB has a 865G chipset. I'm new to this hardware. I really don't know much about this new MB, is this a good model? I heard Asus MBs were good for overclocking. I am not planning on overclocking, but with the 5 case fans (modded in 5th) and high performance thermal grease I got, I'm tempted to try. I got a good deal, about 250 bucks for the MB with memory and processor. All brand new. Sounded fishy at first though.
if a mobo doesnt give you any problems at all and performs great just stick to it.. i have went though at least 10 mobos in my life... some went bad... but most were good and never crapped out on me...
the first video card i owned was an intel 8mb video card.. played halflife on it.. at amazing graphics! lol....
All you need is a good graphics card and you should be set ;).
Is there something bad about the extreme graphics? It looks ok, I haven't tried any games on it yet though.
its 3D capabilities are horrendous! you might be able to play Duke Nukem on it :eek: J/K. If I was you and have a few more bucks, get a (assuming you are using AGP) a 7600GT or 7600GS AGP card. That will net you some new life into an "aging" PC
y3k said:
http://www.asus.com/products4.aspx?l1=3&l2=11&l3=0&model=1276&modelmenu=1
That's the board. I have 220 bucks on me so I might be able to find a good card. Not too much though.
Is my memory fine? it is working smoothly right now with 512 DDR400. I might not get another 512.
Definitely get another 512mb.
Maybe look into a X800 series video card also. X800XL can probably be had under $100. Not sure what else is out there in AGP for cheap, but you'd really notice a big jump moving away from 865G graphics.
Not crapping, but for $250 you could have gotten a lot better (core 2 duo 6300 + mobo + 1GB DDR2).
You overpaid by at least $100.
You really have been out too long. :D
sniper991122 said:
considering the 6300 is about $189, that leaves you $61 for a motherboard and a gig of memory... I fail to see your math
Fry's/Outpost has the 6300 + ECS mobo for $169 regularly.
$80 will get you 1GB of DDR2 pc4200-5300.
Damn. No refunds.:( I'll just get the gig of memory and wait awhile and buy the duo to put in the P5PE-VM.
