Endari1127
- Sep 20, 2015
Hi guys, i'm looking to replace my ancient Q6600, the first system I've ever built, with [H]ardforum's help back in 2007. Looking for your expert advice, once again. Many thanks in advance for your help!!
Gaming
1500 to 2000, tax included (newegg is tax free no?)
Rockville, MD (20852 zipcode)
CPU, RAM, Gfx card, Liquid cooling, power supply, case
Will be reusing Samsung SSD (840 Pro Series 256 GB SATA 6GB/s Solid State Drive MZ-7PD256BW)
6) Will you be overclocking?
Yes, at least a little bit
Currently 19inch, looking for recommendation too
Within the next few weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Crossfire support, SATA 6gb/sec,...
Yes 64bit windows 8.1
This is the build i came up with on pc hound....
https://pchound.com/fvv15u/
I'll be mostly gaming on this, plan on doing some overclock - i'm currently running an old ass 19 inch samsung monitor (also from 2007
)....so I figured I'd like to spend at most 2000
Is liquid cooling worth it? also the mobo I've chosen seems kinda pricy (ASUS ROG MAXIMUS VIII HERO $228.99) ...same goes for the memory G.SKILL 16GB (2 x 8GB) Ripjaws V Series $205)....
Should i just buy the cheaper mobo/memory and go with fan cooling?
Thanks for any advice on the build.
Cheers,
Dave
Gaming
Cheers,
Dave
