FINALLY #2! Nvidia chipset for LGA775 mATX!
Dillusion
At another corner of the wall, we saw the Gigabyte N73-PVM-S2H, this is a board based on the GeForce 7050/630i chipset meant for LGA775. It is commonly known as MCP 73
Nice of them to join the party! :) That particular board smells like budget, though.
one of the pci slots is pretty much useless too. ehh if it'll do me 515fsb with great internal latencies, then maybe.. just maybe :)
It's green? Since when does Gigabyte make green Mobos?
Yeah, I vote for the it's very budget as well. However for the masses it should be a fairly nice board.
If it is a budget board, itll be great for HTPC's with 7000 series purevideo and HDMI.
Remember the abit LG-81 only had two ram slots and it was a great overclocker for what it was.
You could always get 2 gig chips if you really wanted those extra gigs.
For me it's the problem of being stuck with what's in it unless I buy a larger set of memory instead of being able to just throw in another identical set if I need more.
Dillusion good point on the purevideo, I had forgotten about that. Perhaps I'll use one of these for my new media pc build instead of the AM2 Abit board.
Interesting. First time I've heard of a 630i. Watered down version of the 650i?
the reviews on the amd boards have it not doing so well. not much of a clocker. but early bios's too
I hope they can fix that. It'd be a real shame if it isnt as good as the NF-M2.
Take out the dash and you get this: http://www.sweclockers.com/nyhet/6029-nvidia_visar_upp_mcp73_pa_computex/ Anyone speak Swedish?
Quick and dirty translation:
"Even though Nvidia hasn't released MCP73 yet, many manufacturers where showing motherboards built on this design at the Computex show.
A previous rumor said that MCP73 would be launched in June this year, but it remains to be seen if this is true.
The chipset will be available as different version with or without integrated graphics and in budget versions. The product name will likely be Nforce 630i and it's designed for the 775 socket and freqs up to 1333 mhz.
The IGP version will have a graphics card called Geforce 7050, supporting Direct X 9.0c, shadermodell 2.0 and hdcp/hdmi. The top model will probably support SLI but probably not the budget versions who will likely only have one memory channel.
At the current Computex Taipei exhibit plenty of MCP73 based motherboards have been shown. We have, among others, seen MCP737MA-S2H from Foxconn, MCP73T-M from Ecs, N73PVM-S2H from Gigabyte as well as 775GT3 from Jetway.
There is no doubt that MCP73 competes with Intels P35 and G33. Now ther just remains to be seen when the first motherboards hits the market and when Nvidia officially announces the chipset".
(Sorry about the bad grammar, I basically just did a word for word translation.)
Here is another one, from BIOSTAR
Notice the two unused traces for more memory DIMMS
FRom that translation, its good to hear of future SLI boards with updated chipsets for SLI.
Nothing on these?
Been way over a month. And why can't they put PCIE on the 1st slot with pcie on 2nd and the last 2 PCI?? GRR
Is that an LGA775 socket with an AM2 mounting frame? Or is it Socket 1207 (which would be a strange choice for a MicroATX board)?
Yes, it's an AM2 mounting frame. It looks like 95% of this board is borrowed from their AM2 counterpart, TF7050-M2. Notice the similarities right down to the two angled surface-mounts at the bottom end of the PEG slot. It's like they kept as much of the board as they could, and then just cut out the parts for the socket, RAM, and PWM's.
Credit where it's due
If only biostar would put the ATX power connector in a "normal" location.
