Final Thoughts on ~$2280 USD mini ITX PC?
Hello
In early June I will be purchasing new computer hardware for a new PC I will be building using the Dan Cases A4 SFX (version 2) computer case. I have a maximum spending budget of $2280 USD, and will be purchasing the parts from Taipei during Computex, where they use US currency. The prices in Taipei should be the same as US prices (or even cheaper)
I will also use the PC with a 4K 60hz G-Sync 27 inch monitor I will be ordering at a later date, for video editing applications (Vegas Pro 14 Edit) and for running modern videogames at 4K resolution. I will be building the system to last for a minimum 5 years before I upgrade anything.
I have an older desktop I built in early 2014, using Intel i5 3570, Z77 motherboard, 8GB DDR3-1600mhz SDRAM and Radeon R9 270X, though I will be unable to use anything from it due to size limitations in the Dan Case.
What do you think? Any last minute changes?
PCPartPicker part list: https://pcpartpicker.com/list/xZCtnH
Price breakdown by merchant: https://pcpartpicker.com/list/xZCtnH/by_merchant/
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor ($324.98 @ SuperBiiz)
Motherboard: Asus - ROG STRIX X470-I GAMING Mini ITX AM4 Motherboard ($209.99 @ B&H)
Memory: G.Skill - Trident Z 32GB (2 x 16GB) DDR4-3200 Memory ($369.98 @ Newegg)
Storage: HP - EX920 512GB M.2-2280 Solid State Drive ($199.99 @ Newegg)
Storage: Seagate - BarraCuda 4TB 2.5" 5400RPM Internal Hard Drive ($131.78 @ Amazon)
Storage: Western Digital - Black 1TB 2.5" 7200RPM Internal Hard Drive ($62.99 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card ($749.99)
Case: DAN Cases - A4SFXV2-S Mini ITX Desktop Case (Purchased For $0.00)
Power Supply: Corsair - SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply ($114.88 @ OutletPC)
Case Fan: Noctua - NF-A9 PWM 46.4 CFM 92mm Fan ($16.59 @ OutletPC)
Other: Asetek 545LC 92mm AIO CPU Liquid Cooler + AM4 Bracket ($92.00)
Total: $2273.17
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2018-05-14 07:28 EDT-0400
I just thought maybe the new Cryorig C7 Cu (Copper) cooler would be a better idea, combined with slim 14mm fan to avoid air turbulence. It would also be a bit cheaper. What do you think?
PCPartPicker part list / Price breakdown by merchant
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor ($319.99 @ Amazon)
CPU Cooler: CRYORIG - C7 Cu 40.5 CFM CPU Cooler ($50.00 @ Amazon)
Motherboard: Asus - ROG STRIX X470-I GAMING Mini ITX AM4 Motherboard ($209.99)
Memory: G.Skill - Trident Z 32GB (2 x 16GB) DDR4-3200 Memory ($443.98 @ Newegg)
Storage: HP - EX920 512GB M.2-2280 Solid State Drive ($189.70 @ Newegg)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC2 Video Card ($749.99 @ B&H)
Case Fan: Noctua - NF-A9x14 29.7 CFM 92mm Fan ($15.89 @ OutletPC)
External Storage: Western Digital - Elements 4TB External Hard Drive ($95.00 @ Amazon)
Total: $2206.01
Generated by PCPartPicker 2018-05-20 06:44 EDT-0400
dont think ive seen the c7 on a 2700x yet. at stock speed it might be fine but id look for other user results first.
