Final parts for my new computer!
OK, after much discussion (mostly about compatibility issues) i took all your advice and finally picked out my parts for my first computer build! Again, I am building a pretty bottom of the barrel computer, not to use, but pretty much just for the experience of building it. Can you please look at all my parts one more time and make sure I don't have any compatibility issues before i put my order in? Thanks a bunch!
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103067
Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813185113
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820134116
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817256032
Hard Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148231
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147111
DVD Burner - http://www.newegg.com/Product/Product.aspx?Item=N82E16827106228
EDIT
CPU - AMD Athlon 64 X2 3800+ Windsor 2.0GHz 2 x 512KB L2 Cache Socket AM2 65W Dual-Core Processor - OEM
Motherboard - PC CHIPS A15G (V1.0) AM2+/AM2 NVIDIA GeForce 6100 Micro ATX AMD Motherboard
RAM - Kingston ValueRAM 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
PSU - SILVERSTONE ST400 400W ATX 12V 2.2 Power Supply
Hard Drive - Seagate Barracuda 7200.10 ST380815AS 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive
Case - Rosewill R102-P-BK 120mm Fan MicroATX Mid Tower Computer Case
DVD Burner - LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 20X DVD±R DVD Burner
Despite popular belief, no, we don't memorize newegg part numbers. ;) Please list product names along with those links so we don't have to click on all of those.
Thanks.
EDIT: Better yet, please close this thread. You have multiple threads all discussing what seems to be the same build.
http://hardforum.com/showthread.php?t=1361388
I'd wait until the Core i7 comes out before buying any motherboards or CPUs. It will drive down the prices of both the Core 2 Duo's and Quads as well as the Phenom and Athlon processors. Everything should drop in price across the board. (Well motherboards and CPUs anyway.) Don't forget there will also be a sub $300 Core i7 part if the rumors hold true. Maybe worth looking into for some folks who might benefit from what it has to offer. (General statement, not meant for the OP.)
Also new RAM modules are coming for Nehalem. So that may drive down the price of existing dual channel kits. Something to think about.
