FINAL decision needed!
funnyray
I need to make my FINAL decision on my build, going to order within a week. So PLEASE help me choice.
I'm using a Dell 22' monitor (UltraSharp 2208WFP), will do SLI or CF later, and WILL NOT overclock on this machine.
Tell me which set up should I go with (SLI/CF), and the type of Memory, Cooler, PSU, vote from the list please.
Thank you!!!!
Option 1 - SLI
CPU Intel Q9550
GPU EVGA GTX280
MOBO ASUS Striker II Extreme 790i Ultra
Case COOLER MASTER RC-690
Cooler (see below)
PSU (see below)
Memory (see below)
HDD Western Digital Caviar SE16 WD2500AAKS 250GB (*2)
ODD1 ASUS
ODD2 Samsung
OS Vista 64bit
Option 2 - CF
CPU Intel Q9550
GPU SAPPHIRE 4870X2 (as soon as it is available on market)
MOBO ASUS P5E3 PREMIUM/WIFI-AP
Cooler (see below)
PSU (see below)
Memory (see below)
ODD1 ASUS
ODD2 Samsung
OS Vista 64bit
Memory
1. OCZ Platinum 4GB (2 x 2GB) SDRAM DDR3 1600
2. CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
Cooler
1. ZALMAN CNPS 9700 NT 110mm 2 Ball Ultra
2. Thermaltake CL-P0114
3. XIGMATEK HDT-S1283
PSU
1. PC Power & Cooling S75QB 750W
2. CORSAIR CMPSU-750TX 750W
3. BFG Tech ES-800 BFGR800WESPSU 800W
4. Thermaltake W0131RU 850W
why do you need crossfire or sli. i run the same monitor with my 4850 and ive been spanking every game out there
Neither Option 1 or 2. Both options use slow hard drives and expensive DDR3 RAM that has not been shown to definitively provide a major performance increase over current DDR2 RAM. In addition for a 22" monitor, you do NOT need Crossfire or SLI. A single HD4850 is actually more than enough for a 22" monitor. So a HD4870X2 or a Crossfire setup will be major overkill. In addition, the Q9550 is not worth its $500+ price. In a few more weeks, the price of the Q9550 will drop to ~$350 and will be worth it then. However at its current price, totally worthless. And finally, those $300 motherboard do not have a major enough performance advantage over $150 or even $100 motherboards out there.
So I recommend downgrading your motherboard, RAM, CPU, and possibly video card choice. You could easily get 95% of the performance of either builds for 75% of the price or less.
Cooler: Definitely the HDT-S1283
PSU: Definitely the Corsair for $115 from buy.com or provantage.com
Oh and one last thing: the HD4870X2 won't be out next week.
QFT. You found the point of diminishing returns and blew straight past it at full speed. Listen to Danny.
Definitely waaay... too much money to spend on a gaming rig especially for only a 22" (1680 x 1050 resolution). Even if you did have the money to burn. A build under $1,000 will suffice.
ROFL... QFT.
DDR3 is a waste of money and so are Asus boards that cost more than $200. :p Oh, and Intel CPU's that cost more than $350 are typically a waste of money, but not as much as the other two I mentioned earlier, lol.
I agree with everyone who is agreeing with Danny. Neither option is optimized in either the price or performance direction. Danny's advice will direct you to a faster setup for less money.
Being the far most expert on builds I would say sli or crossfire is far beyond what you are trying to do. I swear i didnt copy anyones idea! /chuckle
Rockjay420 Limp Gawd, 2.8 Years
I like the second setup better, but why WILL NOT you overclock>?
cus this set up is good enough for me 2 do anything, and i dont wanna hurt the system by overclocking.
Just a question. Anyone know for sure the Xigmatek 1283 will fit in a CM-690 case? I've heard that it might not (and was planning a Zalman 9500 for that reason), though I'd prefer that cooler with the bracket.
Yes, the HDT-S1283 fits in an RC-690 for sure.
That's good, I'm gonna go with that then (as should OP). I read a review (on newegg maybe) where someone had that case and had to do serious mods to it in order to get the Xigmatek in.
