That's it... 2 more W2's and I'll be ordering my new computer! This spec was put together by you guys not too long ago. I want to keep the cost under $1000, and I'm also aiming for a quiet PC. I do have a few questions, but I am more interested in hearing your thoughts or comments if this should be upgraded in any way. Anything that can be done to cut costs I will do. I will probably swap out the PSU, as I don't need modular at this time. This is a non-SLI gaming PC, I intend on staying with my 22" LCD screen and not going dual.
Case: Cooler Master 690 ($80)
Motherboard: Asus P5Q Pro LGA P45 ($119)
Processor: Intel C2D E8400 3.0GHz ($165)
HSF: Xigmatek HDT-S1283 ($36)
HSF Retention: Xigmatek ACK-I7751 ($9)
Video: MSI N260GTX 192cores ($230?)
Memory: OCZ Fatal1ty 2x2gb DDR2 800 ($39)
PSU: Corsair Modular 620W HX - ($160)
HD: Western Digital Caviar 7200RPM 500gb SATA ($60)
CDRom: LiteOn 22x DVDRW w/ Lightscribe ($30)
Total cost before taxes & shipping: $928
A few questions:
1) What are your thoughts for this?
2) Someone in my other forums recommended going to the E8500 C2D + 1066MHz memory, as I would be able to reach 4.0GHz speeds at stock voltages. What are your thoughts, and should I do this?
3) Since I'm looking for a quiet system, if I go with the CM 690, should I replace the stock 120mm fans w/ some aftermarket ones?
I appreciate any input you guys can give me on this, thanks!
A few questions:
