Main purpose for PC is video editing, 2nd is gaming. 5870 is a must since it can support 3 monitors. All the parts been carefully chosen. I have 3 monitors 24" Planing on ordering this as soon as I can. Would like to order today (Monday) This PC will be Overclocked as well to 4.0Ghz
MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX $199
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225COOLER Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $239.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Desktop Processor BX80601930 $289.99
http://www.newegg.com/Product/Produ...2001&cm_re=Prolimatech-_-35-242-001-_-Product
Prolimatech Megahalems Rev.B CPU Cooler $62
http://www.newegg.com/Product/Produ...0148348&cm_re=c300_ssd-_-20-148-348-_-Product
x2 Crucial RealSSD C300 CTFDDAC128MAG-1G1 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) $334.00 (each)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150490
XFX HD-587X-ZNFV Radeon HD 5870 (Cypress XT) 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card -$30.00 Instant $369.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152175
x3 SAMSUNG EcoGreen F2 HD154UI 1.5TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $269.97($89.99 each)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
CORSAIR HX Series CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply $169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835154003
Tuniq TX-2 Cooling Thermal Compound $4.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231304
x2 G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 ($154.99 each)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103072
COOLER MASTER Megaflow 200 R4-LUS-07AR-GP 200mm Red LED Case Fan $21.80
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
x3 LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support $77.97 $25.99 (each)
About $2,780 Total
I will also be adding a 120mm fan for the heatsink. I selected "ULTRA KAZE" and "APEVIA CF12SL-UBL"
I also would need a very good sound card, needs suggestions. Also in regards to the video card, his TV is currently connected via S-Video cable, but 5870 doesnt have an S-Video, can someone suggest a good adapter plz?
For the sound card I was thinking about http://www.newegg.com/Product/Product.aspx?Item=N82E16829102021 or http://www.newegg.com/Product/Product.aspx?Item=N82E16829271001 something good that supports 7.1
Thanks
About $2,780 Total
Thanks
