Final Build List - Will be ordering in an hour...
Phrozt
Minus the case, because I'm still trying to decide on it.
This is your last chance to talk me out of anything!!
MSI P6N Diamond LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
http://www.newegg.com/product/product.asp?item=N82E16813130080
$279.99 $279.99
EVGA 768-P2-N831-AR GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card - Retail
http://www.newegg.com/product/product.asp?item=N82E16814130072
$559.99 $559.99
SILVERSTONE ST75F ATX12V / EPS12V 750W Power Supply - Retail
http://www.newegg.com/product/product.asp?item=N82E16817256009
Model #: ST75F
$179.99 -$20.00 Instant $159.99
Intel Core 2 Duo E6700 Conroe 2.66GHz LGA 775 Processor Model BX80557E6700 - Retail
http://www.newegg.com/product/product.asp?item=N82E16819115002
$320.00 $320.00
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model BL2KIT12864AA1065 - Retail
http://www.newegg.com/product/product.asp?item=N82E16820148069
$224.99 -$30.00 Instant $194.99
TWO - Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/product/product.asp?item=N82E16822148140
$79.99 $159.98 (price x2)
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06 - Retail
http://www.newegg.com/product/product.asp?item=N82E16827106072
$43.99 $43.99
Microsoft Windows XP Professional With SP2B 1 Pack - OEM
$139.99 $139.99
Arctic Silver Ceramique Thermal Compound - OEM
http://www.newegg.com/product/product.asp?item=N82E16835100009
$4.99 $4.99
ZALMAN 9700 LED 110mm 2 Ball CPU Cooler - Retail
http://www.newegg.com/product/product.asp?item=N82E16835118019
$79.99 -$20.00 Instant $59.99
Subtotal: $1,923.90
I just put my system together a week ago, very similar so I'll post my comments on each part.
$279.99 $279.99
Haven't read any reviews on this yet, but I guess the performance will be on par with all the other 680i boards. I have the evga 680i and love it... but I would have def put up the extra $50 to get x-fi built in.
$559.99 $559.99
I just got this card and it's great. It won't overclock that much... but I'm hoping the ultra OCd comes down in price in 2 months and I can step up. If not, I really doubt the 8900 will be out considering Nvidia has no competition w/ati atm.
Model #: ST75F
Great PSU, I bought the Corsair HX 620 which can do 8800gtx SLI, but this is probably a safer bet while being a little more expensive.
$320.00 $320.00
Why spent $100 more for the 6700 over the 6600? My 6600 OC'd to 3.4 w/barely any work. I'm sure I could get it higher if I took the time but right now I don't have any games that don't run fantastic so I'm not worried about it yet.
Great memory. I bought Buffalo Firestix and they aren't as good as I read they were.
I was going this route, but I decided to buy 2x500gb 7200.10s. $100 more for 360gb more in 2 drives instead of 3 (if I were to add another later on).
$43.99 $43.99
I bought this drive and it is REALLY loud, but I don't use it that often so it really doesn't bother me. Honestly the loudest part of my system (Antec 900 case and thermalright ultra 120 extreme) is the seagate 7200.10 drives.
$139.99 $139.99
You don't have an old copy from your last system you could use? Honestly I'm using Vista Ultimate and I love it. It was crap when I tried it on my old system, but with all this horsepower it runs like a dream and I'm having no compatibility issues with *new* games. And old ones I have managed to fix (thanks google) to run no problem. Also this way I don't have to upgrade down the line when Crysis comes out.
$4.99 $4.99
I used the thermal goop that came with my Thermaltake Ultra 120 Extreme and it is fine. But it's only $5 if it makes you feel better, why not.
Not a bad cooler, but for that price I'd much rather go with a Tuniq or Ultra 120 (extreme or regular).
And as for your case decision. I really loved the Silverstone cases but they were just too expensive. I bought an Antec 900 and it's an absolute dream for air cooling. The only downside is the cable management, which can be remedied with a dremel and a few hours... or you can just tie the main cables down and get it pretty clean... just takes some time. Also, my Thermalright Ultra 120 Extreme didn't fit, but 3 mins later the dremel took care of the small piece of steel in the way.
Wow anonuser... thank you for the in depth reply!!
I lied.. I didn't buy it yet because I still can't decide on the case ( :( ) so I'll pick a couple points to discuss:
Yeah, I wanted to go w/the 620, but SLI would probably mean an upgrade in the future, so I better just spend an extra $10 and get something that will go the distance.
The price cuts gave this CPU top spot in my mind. THG charts put the performance of the 6700 way above the 6600, so I figured OCing the 6700 would be even better!
The real deal here is the price!! There's a $70 rebate on those sticks I'm looking at!
Actually... I'd like to go to a 7k1000 down the line when the prices drop, and as it stands, 2x320s are already more space than I currently have... hopefuly they'll hold me till the price of the 7k1000 goes down... heh
hmmm really loud?? is it still worth it???
I don't have a legit copy ;/. I do play some older games though, with some older third party apps.. so I'm really hesitant about getting vista w/all the gaming horror stories I've heard (this will be primarily a gaming rig)
Yeah... the thing is, I had a run in w/Zalman customer support and they were WAY over the top in service... just unbelievable ( link to my story: http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&t=221923&highlight= )
Because of this, I'd really like to stay w/zalman, even though I know there are better options out there :/. I wanted to get the zalman PSU, but I felt that was just shy of the power that I'd need w/SLI.
actually.. after thinking about it, I think I will go w/the e6600, because I DO plan on upgrading down the line... so the surprise will be greater :p
Yeah, the noise is worth the fact that it's SATA (for me at least). If you use your cd/dvd player ALL day long then maybe look to a samsung or something a little quieter.
Other than that.. go for it.
And I really like the Antec 900. Really quiet, cheap, and GREAT airflow. I like how it looks too.
Hi,
The E6600 is a better value than the E6700, as the only difference between the two are the stock speeds, and the fact that historically, the E6600 has proven to be as good as, if not better an overclocker. (Take a look at OC comparison post on the Intel CPU forum.) In fact, out of all Core 2 Duo chips, the E6600 has proven to be an overclocking champ, even beating out many X6800s on air.
With a good air cooler, you should be able to reach 3.6 Ghz on a current batch E6600. That's not too shabby at all, and you'll still save over the E6700 at stock. For the best in E6600 air cooling, look no further than the Tuniq Tower or Thermalright Ultra 120.
Good luck,
Mark.
hmmm.. a samsung? I might want to.. I still play quite a bit of warIII :D
Yeah mark.. I think I am going to go w/a 6600. The price cuts REALLY make me want a 6700, but I think the smarter choice is a 6600. It's fun to play w/numbers until the bill shows up! lol.
Indeed :)
Well it looks like you've put together a solid build. I agree that the Antec 900 is an excellent case for the money, providing great airflow. You just have to like the industrial look of the thing. If you're looking to spend more on a case, say double the price of a 900, then Thermaltake's Armor Series is worth a look, as is the Cooler Master Stacker 830/832. For the best of the best, but somewhat approaching triple the price of the Antec 900, look at Lian-LI and Silverstone's high end offerings. I have a TJ-09 and love it. Easily it's the best case I've ever owned.. an outstanding work of craft.
Good luck with the build,
Mark.
Actually I was already highly considering the armor series (and the antec 900 for that matter :))
I'm trying to pick the best parts to minimize buyer's remorse... heh. Both from "man I didn't spend enough on this" to "I really didn't need this.."
Ahh well. At some point you just have to jump in.
Since you're going with an E6600, theres no need for DDR2-1066 ram, but I guess that rebate is enticing. I, personally, don't go for rebates over $50. The one exception to that was for my 200GB HDD from Dell (in 2004; $225 - 200MIR= $25, w00t!). I think buy.com had the ballistix ddr2-800 for $99AR, but that deal may be dead by now.
9 * 266 = 2.4Ghz, DDR2-533 (stock speed)
9 * 333 = 3.0Ghz, DDR2-667 (mild OC)
9 * 400 = 3.6Ghz, DDR2-800 (high OC)
As mark said, the E6600 has as much or more OC'ing headroom than the E6700. Also, 3.6Ghz is the avg max on good air cooling... so as you can see, no real need for DDR2-1066. The only good thing would be tighter timings, but thats too much of a price premium for the little performance gain.
I actually ended up NOT going for that ram because you had to have the rebate postmarked by the 18th. Since there was no way that I'd be able to garauntee my parts in and a postmark back by the 18th, I decided not to risk it. It might be possible to squeeze it by, but I knew already that I wouldn't be getting much of a gain from that speed, and being stuck w/the $100 overhead (the patriot extreme is $98 w/rebate) wasn't worth the risk.
I called newegg and got the crucial... I re-read the rebate thing this morning and it had to be postmarked by *6*/18.. not 5/18, when the rebate offer expired...
That's what ordering a comp at 12:30 in the morning will do to you :p
I have the samsung DVD/RW in my sig and it's nice. You can hear the disk spin up when it's loading data, but it's quiet when it's not. It sounds like a loud 120mm fan. Watching movies or playing games it's fine, it's only when installing software or transferring large amounts of data does it crank up.
At 1.45v my 6600 maxes out at 3.38ghz OC... and this is the new batch.
The new batch doesnt seem as good as the old ones. And yes, I have an ultra 120 extreme w/scythe fan
You do have to remember that overclocking is never a guarantee. You may have just gotten an E6600 that could only do 3.38Ghz. What it comes down to is, luck of the draw.
Is there any reason to not get MIRs over $50?
I'd just hate to be out $70 if something goes wrong with that rebate. Its not worth my time and effort to fight for a rebate, should the need arise. Therefore, I ask myself if I could live with the price without the rebate. Don't count money as yours unless its in your "hands."
I've got a couple friends with E6600's from the newer batch. One is having trouble getting past 3.2 and the other is at 3.4Ghz on stock cooling, I believe.
