Final build check, before I buy
2fast4u2c
I've been holding off buying my new PC (due to no new graphics cards coming out that dethrone the GTX/Ultra), but i now think I'm just going to go ahead and buy.
Here is my planned gaming setup (budget of around $2700AUD):
Mobo___Gigabyte ga-p35-ds3r
CPU____Intel Core2Duo e6850 (picked over q6600 as i don't plan to overclock)
RAM____Corsair Twin2x2048-6400C4 - 2x1GB
GPU____Nvidia 8800GTX (any particular brands that are better?, eg: MSI, BFG, XFX)
Case____Antec nine-hundred
PSU____Corsair HX620
HDD____500GB samsung
Screen__22" Samsung 226BW
KB_____Logitech G15
Mouse__Razer DeathAdder
including OS and optical drives, etc this build totals out at $2642 AUD from a fairly average pc store near where i live.
I'll be mainly be using this for FPS games (CS:Source, TF2, CoD4, etc) and WoW :p
Critique/advice would be extremely helpful, thanks guys :D
Overclocking is not the main reason here, it’s not that e6850 is better than Q6600 unless you OC the Q6600
If you frequently update u’r hardware go for the e6850, if you have long plans for the processor go for the Q6600 it’ll be good for now and better in the future
EVGA & XFX :D
And get some mouse that has some liquid in it with transparent cover, and tell people that you oveerclocked it :D
I would really think about getting a 8800gt, since your LCD's resolution is 16xx by 10xx you can prob get away with using the cheaper GPU.
I also would say to go for the 8800GT. With the money that you will save on the graphics card, you can bump your system up to 4gb of ram. I have a very similar system and it screams. Plays all the games that you have listed at max settings (but then again my monitor only goes to 1280x1024). Anyways, the new 8800GTs are just as good as the GTX IMO. Especially if the FPS games you are looking at are ones like source and wow, that have good graphics but have been around for a little while. I get consistent over 100FPS in CS:S with my setup in my sig.
will i notice a performance increase going from 2Gb->4GB RAM? And with a 32bit OS i can't utilize all 4Gb so wouldn't 3Gb be better? (i hear 32bit can use something like 3.2Gb), though RAM is cheap so maybe going 4Gb is just as easy.
I only went 8800Gtx>8800GT as, while their performance is close, I would kinda like to know i have a little more headroom at 1680x1050 for games like crysis.
It depends if the games you play actually takes advantage of 4GB of RAM or if you do a ton of multitasking.
Yes might as well get 4GB of RAM while prices are still low. However, you should think about getting a 64bit OS like Vista64bit, which actually has better support driver wise than Windows XP 64bit, in order to use all 4GB of RAM. And some games do run faster in 64bit as well.
Also, really think about the E6850 choice. Here in the U.S, the price between the E6850 and E6750 is $100. Yet all you get for that extra $100 is 333Mhz? Do you really want to pay that much money for a measly bump in speed over the E6750?
Also for that same price, you can get the Q6600. Yes the E6850 is faster in games NOW but in the future, games will take advantage of quad-cores. In fact, the Crysis developers themselves have recommended going for a quad-core CPU over a higher clocked dual-core for Crysis:
http://shacknews.com/featuredarticle.x?id=639
We support both 64-bit and multi-cores. Multi-core will be beneficial in the experience, particularly in faster but also smoother framerates. 64-bit and higher memory will yield quicker loading times. We recommend quad core over higher clock.
QFT.
