I had my internal desktop 2TB HDD running all good with full health... but the moment i got near 1.50TB of data.... my drive started showing all sorts of Bad sectors.
So all i wana ask is - Is it not advisable to fill the HDD to its limit (OS partiion is always separate in my HDD).
If that is the case then i might go for 3TB...
Remember: There is no shock, power failure or anything tht might had created this situation.
On the Side-Note, HD Sentinel showing 2000 Bad sectors, but Seatools is showing all OK and i wana get it RMA... any clue what shall i do so tht seatools shows sum errors as well so tht i can submit the HD.
