I am looking for suggestions on hardware to use for building a file server. This'll be my first server build --
A few things I would like:
- The file server will be running some flavor of linux with Samba and TrueCrypt.
- My budget is $1000. I'd like at least 2TB of usable space (is this reasonable within budget?)
- Don't care much about speed, as long as it's not slow as a snail. No video editing or anything.
- I'd like as close to 100% uptime as possible, within my budget range. If things happen, I can rebuild the server.
- At least RAID 1 redundancy.
- This server might also get some use as a low-volume VMWare VM server or a low-volume web server.
- I would like as much disk space as possible within my budget
I'm wondering about:
- server-specific technologies such as server mobos/procs, SCSI, SAS, and ECC memory -- whether or not it's worth it to go this way over normal desktop-level hardware.
- Should I go with one single disk for the OS and then separate RAIDed disks for data storage? Or store files and OS on the same drive so that the OS gets mirrored as well?
Thanks!
Thanks!
