i7 920 @ 4GHz, GTX 480 @ 835MHz core / 4.05GHz RAM, 3GB DDR3 1600 @ 8-8-8-24, Intel X25-M G2 80gb SSD
Results:
Score: 4555
Load time: 11738ms
I am disappointed. I expected a higher score. I am running the latest NVIDIA 3D driver version 1.29 which include their 257.21 driver. I don't suspect the 3D driver is hurting performance since the benchmark runs windowed... meaning no 3D.
720p Low
1080p HighThe game doesn't support SLi or Crossfire currently
Why in the hell would you not just print screen?Core i7 3.6GHz + 4850X2. I used a modified DLL to run in full screen and renamed the application to 3DMark06.exe to get a true result which would make more sense as the game would be able to run in full screen and should support multiple GPUs.
Without renaming it, it will ignore anything but your first GPU.
720p Low
1080p High
I apolgize for the funny looking images, this was done on my Sony GDM-FW900, which needs to be recalibrated which I'll end up doing next week once I get paid to buy the cable.
hi rez...
What's your high score with that setup? I'm about to have a really similar setup and I'm curious.
Ok, so I have new scores
I was able to locate a modified .DLL file that allows for full screen action. Along with the file rename, scored the following - all High Res
3450 - Quad Fire - Full Screen
3391 - Crossfire - Full screen (Unchecked the Crossfire X box in CCC)
2204 - Single GPU Full Screen - (Unchecked Crossfire X box, and Checked "Disable Catalyst AI")
To confirm my results, I pulled the .DLL file from the benchmark folder to run in Windowed mode again
1488 - Quad Fire - Windows Mode
1490 - Cross Fire - Windows Mode
1481 - Single GPU Windows Mode
This was on my C2D OC'd to 3.6 along with running the bench from my SSD.
While the scores improved, the display was awful. Screen tearing in QuadFire is putting it lightly, more like screen shredding. The little blue bar looked like a seismograph the entire time.
Crossfire improved on the screen tearing, but still hard to ignore.
Single GPU was more to the norm...a smoother blue bar, but low FPS symptoms.
From what I've seen a Q9550 with a 5850 hits just over 3600 in windows mode, so I'm not sure if a Q9550 is a good idea, or simply dump the X2's fora 5xxx, or an upcoming 6xxx card.
I'll bench hers tonight and see if I can get a comparison.
Mind sharing where you get this dll?
So does the actual beta run like crap compared to the bench?
hi rez...
[IMggG]http://i204.photobucket.com/albums/bb41/humadragon/wrong.jpg[/IMG]
Nobody asked for your opinion, sir. Mind your own business and the world will be a better place.BTW: To the guy above me, taking a picture of the monitor, you fail.
