MassiveOverkill
- Jul 8, 2005
Exactly 39,900 higher, making it roughly 39,900 faster.My my. Nvidia is ruined. That thing numbered even higher then a 5870! It must be wicked fast.
Where the hell is Sonda? He makes passionate love to anything from ATI ending in *770 I thought for sure he would jizz his pants at the mere sight of this!![]()
It's the real deal ya'll. The VRAM is rated at 4.8 Ghz.
All of the HD5770s are rated at those speeds.
there he is. and no it comes with Dirt 25,770.![]()
I heard that game is so real dirt flies out of the screen.
You have to put dirt on your cpu, makes it moar realistic bro!
They mixed the memory speed with the bandwidth. The memory speed is 1200MHz, the bandwidth is 4.8Gbps
Ewiz/Superbiz seems to be owned/operated by Asians (don't pull the race card, I'm a Flip) who can't speak/read Engrish very well. Their website is constantly ridden with errors, some of which are easy to dismiss, others are misleading (I'm not necessarily saying it's intentional).
Screw that, the 45770x4 FTW!![]()
Fermi Killer?
How do you kill a product that does not exist?
If only Nietzsche would be alive...![]()
Don't you mean Pinoy?![]()
Using time-travel to one-up the competition is the sort of underhanded tactic I would have expected from nVidia, not ATi.45770? You mean 4nm. Right?![]()
