Last anyone heard it was cancelled. WAY too hot and power hungry. Fermi will need a respin first.
doubt it would be called the 495 anyways.. since the whole xx5 part was created to represent the 55nm part vs the 65nm part of the GTX200 series cards.. only 2 cards that never got the xx5 designation was the GTX 260 216 core 55nm and the GTS 250/9800GTX+.. most likely will be called the GTX 490 and i doubt its scrapped since nvidia needs that to milk every dime they can out of their loyal customer base..
The 5970's GPUs were downclocked to 5850 speeds to keep the card's power requirements within PCI-Express specs. If a GTX 495 were based on the current 470 or 480, its power requirements would far exceed PCI-Express specs, which is a Really Bad Thing (tm).
Nvidia is either going to have to reduce power consumption dramatically or just simply not bother with dual-GPU solutions anymore. Considering the checkered history of the 7950GX2, the 9800GX2 and the GTX 295, it would not surprise me if they just focus on getting as much performance as they can out of the 300W envelope with a single GPU and leave the multiple-GPU setups to SLI.
How so? An overclocked 5970 also far exceeds PCIE specs and I haven't seen anyone report any ill effects. It's not a big deal.
A 495 would break that while not being overclocked.
What's your point? The 5970 shows that the PCIE spec is pretty arbitrary, and similarly, a cutoff of "more wattage than an OCed 5970" is also arbitrary. You or I don't really have a clue about what the real cutoff point for wattage is.
Well there were some setbacks when they went to test the card. http://www.youtube.com/watch?v=rdjhn6BY8-E![]()
Hence the 495, IMO
We may see a new revision of Fermi, one that consume less power,
nVidia didn't release a dual GPU part for the GTX 280 either. Not till they release the 285 and 275, and the 295 is base on 275, the new revision chip, except with lower clock
Doubt they can put 2 of current Fermi on one card
