EDIT: sorted most of this out, skip to post #6/7
Hey guys, im currently on a macbook (and hence have not registered up until now, but i've been a long time reader, folks at the irc channel convinced me to post (and subscribe with the craglist sex story
) - and after realising i cant even try the bloody spore creature creator trial on it, i've flipped, come to my senses and decided not to wait for the mac pro Nehalem revision and just get a rig now.
Half the reason i wanted a mac pro was because of its low noise levels. So with everything im buying, im taking into consideration noise levels.
Reasons to buy now VS later (Nehalem) (mostly from what i've learnt from searching the forums):
*i hear nehalem will be expensive at early release
*consumer cpus wont be available for a while also (not sure of the time scale)
*Nehalem mobos will go through a few revisions before being optimum (taking a few months i take it)
*I will be gaming a bit - mostly COD4/UT3/Battlefield 2 (and 3 when it arrives) and Starcraft 2 at high resolutions 1920/2560. I'll be photoshopping lightrooming for around 2 hours a day, so i don't think the performance gain will have such a significant affect on me - but i could be wrong, and would appreciate some feedback
*I've been on this POS for too long!
Now bearing those above needs in mind, that i saved up quite a bit for the mac pro already and the fact that I am hoping my system will be nowhere near obsolete (for my uses) for the next 2-3 years (or until the Sandy Bridge dye shrink) these are the product parts I am planning on getting:
1) CPU - Intel Core 2 Quad Q9550, Yorkfield Core, S775, 2.83 GHz, 1333MHz, 12MB L2 Cache
2) Memory - Need more of your advice:
I) I don't want to have to upgrade memory again when i upgrade again, so was thinking of getting DDR3 - But i don't know if i am actually going to be getting a significant improvement over DDR2?
II) I heard from someone on the hard forum's unofficial IRC channel that the ram speed should match that of the CPU's Bus Speed (which at the current CPU i have my eye on is 1333MHz). I will not be overclocking - is there any advantage to getting faster RAM?
III) Should I get 4 x 2GB sticks or 8 x 1GB sticks (forget pricing advantages) - but for a core 2 quad core what would be the optimum configuration, and how much of a difference will it make?
Seeing as I don't really know the answers to the above, i've found 3 suitable (i think) memory options:
(4x2GB) CorsairTwinX XMS3, DDR3 PC3-10600 (1333MHz), 240 Pin, Unbuffered, CAS 9-9-9-24, DHX
(8x1GB) SuperTalent DDR3 PC3-10600 (1333MHz), 240 Pin, Non-ECC, Unbuffered, CAS 8-8-8-18
3) I'm not sure of what motherboard would suit all these needs (so im holding off looking for one until i really know what i am going to need, although i would like to future proof (2-3years) it as much as possible) - i know mac pros have 8 slots for memory which is why i've given myself this option. Oherwise i'll probably go for DDR2/3 1333/1600 MHz 2 GB sticks
4) Im thinking of getting a PSU that has the following:
very quiet, supports max hard drive slots being used, supports all PCI slots being in use + full USB/firewire connections, very quiet, gives me the opportunity should i want it to power another GFX card in either SLI or crossfire - and did i say quiet? But i dont want to go so much over the top when i wont be using its power 99% of the time for economical reasons - although i dont know how significant that would be! Possibly: Thermaltake ToughPower 1200W
5) Hard drives - was thinking of going 2x 500GB 7200 rpm SATA II, one for photos & music, and one for downloads. And i was thinking about going velicoraptor 10,000 rpm - but i dont know about these for sound/reliability/availability in the uk or even about 150gb vs 300 gb - so will probably decide on that later, but i would like my motherboard to be able to support 4 hard drives if i ever wanted to expand. I will also need to research which ones produce the lowest heat and are the quietest
6) Sound card - i know that a lot of motherboards come with soundcards but im not sure if i want to get an external. I currently use my soundsticks 2 (harmon kardon) and very easy to drive headphones ( ATH-AD700 ). I would like the possibility of going 5.1 +. I'm thinking about the Creative Sound Blaster X-Fi Titanium Fatal1ty Pro Series, PCI-Express Sound card however i think i read on some forums a while ago that a lot of people were having problems - but their flash demo sounds awesome! I guess this can always be purchased later
7) Graphics card - alright my monitor is currently a 24" Dell. I'm planning on boosting that up to either the new Apple cinema display 30" or whatever dell has at 30" when the new ACDs are released, so im going to need a bit of a beast unfortunately. Open to recommendations, i'll restate all the games i intend to play (mainly at 1920 or 2560 resolution)
Call of duty 4
half life 1/2 + mods (cs etc)
UT3
Wacraft 3
Starcraft 2
Battlefield 2 & 3
the upcoming new crysis
So bearing in mind i need some hardcore performers to not have to upgrade when battlefield 3 comes out..But i also want silence! Price wise, the GTX 280 is sort of out of bounds really.. i could just about purchase the GTX 260 on a drunken low night but i need the power
. If i was to get the 4870 now, would it be possible to get another by the time battlefield 3 comes out? I don't know about the whole pins and bobs thing for the power supply..and the whole 16x PCI slots?
8) Blu ray writer, and a dvd writer - not in a rush really for the bluray writer. And i shouldnt have too much trouble finding my own but if someone really has an astounding recommendation or would like to comment then it would be much appreciated
9) Case! i have no idea, i want it to look sleek not too many different coloured lights, be able to accommodate all this. Im not sure that i want fans etc becuase of the reason below:
Now if you thought i was pretty clueless:
The sound proofing part. Ok so i would have purchased parts that are as quiet as i can without sacrificing too much in terms of power and efficiency but for true silence, i figured id experiment and try out watercooling.
Again, i don't plan on overclocking, at least, not in the near future at all.
Also problem with that i know a lot of gpus come with some sort of special fan and i dont want to pay a premium for that fan if im just going to remove it, you know?
Anyway, at first i was considering the RESERATOR v2 from Zalman, but after a few negative posts about it failing and its pump not being strong enough im considering the RESERATOR XT although it is pretty expensive, and it isnt as quiet, but if it does the job..i maybe willing to bite.
Also any other recommendations to make it silent? Im planning to use the watercooler to cool the CPU and GPU and maybe memory
Thank you very much for reading, any help is much appreciated for any of the parts at all!
Summary: I would like any recommendations or feedback/comments with any of the parts i am planning on purchasing, or any thoughts about my own reasoning for purchasing now.
I've basically listed out all the system parts i am considering getting and my thoughts around them and would like the pro's opinions!
Formatted to help jump to the key parts since its a huge post
Call of duty 4
UT3
Wacraft 3
Starcraft 2
Battlefield 2 & 3
