fluidimagery
- Aug 9, 2004
I just built my new box last night. I had a shuttle that kept overheating so I decided to scrap that and buy a lian-li HTPC (http://www.newegg.com/Product/Product.asp?Item=N82E16811112126) The case has front panel audio / and usb etc.
I decided to use an Asus A8N-SLI Deluxe board with an FSP Group PSU
http://www.newegg.com/Product/Product.asp?Item=N82E16817104954
The issue I'm having is that I'm getting a noise through my speakers when the hard drive spins, when it's not spinning there is still a slight noise but it becomes louder once the hard drive is active. I've tried the audio jacks in the back of the case as well as the headphone jack in the front. Both jacks do the same thing. Any help would be appreciated. I use the bose quietcomfort 2 headphones most of the time and the noise is unbearable when those are on.
I'm thinking about just getting an aftermarket sound card and trying that. I'm thinking about the Soundblaster X-FI series. Do those have ports on them to run to front panel audio?
Any insight would be appreciated. Thanks!
