ThreeDee said:OP is running XP-64bit ..there is one thing that cuts performance a bit
I was running 32-bit XP and game played smoother ..now its not quite as smooth at same settings under 64-bit XP
ThreeDee said:I run a SLI setup ..and 32-bit XP played the game smoother then 64-bit XP on my setup
I run dual core tho ..
but OP needs to either drop rez or drop some of the eye candy
Yeah Im running those ,without vsync I get 75 fps max and it dips down into the low 20s, and I got the fear patch.ShimmyT said:What nvidia drivers are you running? Are you running 81.85?
So it is the game and not my system!!!!!!![BB] Rick James said:The game runs 70 FPS for me at 1280 X 960 with everything maxed. I notice slow downs when water is introduced.
Great game, but the engine does need some refining. All in all great game IMO.
lee63 said:Yeah Im running those ,without vsync I get 75 fps max and it dips down into the low 20s
Very fuck'n funny, jack ass.xTABx7 said:haha yeah its fear, fear that he cant figure out how to work his $900 video monster
Thanx I will try that. Also thanx to everyone else that has helped outretardedchicken said:Turn lighting down to medium.
This on a fresh install of XP and drivers4b5eN+EE said:id say its your drivers..use driver cleaner to whipe them all (after downloading the newest...just so you dont have to browse for em in 800x600) and reinstall them.....and i dont mean just your video drivers....chipset and sound too....
Yeah the tearing sucks though.Stanley Pain said:Make sure you have Vsync off. I was getting a massive performance hit with it on.
PEBCAK perhaps?michealo said:user error
What does that mean ??PerfectCr said:PEBCAK perhaps?![]()
Who's my friend and yours?lee63 said:What does that mean ??
Ok genius, what am I doing wrong.PerfectCr said:
AA seems to be the problem here, even at 2X it realy makes the game run slow for me.I have the rendering mode set to auto that seems to work well, I will try the messing with the other settings today, thanx for your helprevenant said:Are you sure your machine is in multi-GPU mode? Maybe make sure it is, and try setting the sli rendering method to SFR in the performance and quality "advanced settings" list.
Also, have you tried just going one by one and disabling one feature to see how much of a performance impact it has? I had to do this and finally I settled on: 1600x1200 with no AA, no vsync, no soft shadows, 4xAF, all other options maxed, except for vol light density on medium. I have all of my "computer" (non-gfx) settings maxed also, but sounds on medium. I get 63fps avg, with 2% below 25 and 5% between 25 and 40, then 92% above 40. It's humming along pretty well.![]()
I recently (two days ago) wiped my gaming rig and started over... I think that axtually made a difference... I had so many old Nvidia driver re-installs on that machine... I think even the driver cleaners were missing some things.. anyways, after the re-install things have been very good. I don;t think you should have to go to those means to get this working, but I am just reporting what I have experienced.
Nvidia released some new Nforce4 chiset drivers today... maybe give those a whirl?
http://www.nvidia.com/object/nforce_nf4_winxp32_amd_6.70.html
I am running these with the 81.85 WHQL drivers...
good luck with that!
Great, I hope soThreeDee said:they should have the 64-bit new chipset driver available soon
lee63 said:AA seems to be the problem here, even at 2X it realy makes the game run slow for me.I have the rendering mode set to auto that seems to work well, I will try the messing with the other settings today, thanx for your help
Archaea said:nothing over 1024x768 is required to make me happy on my 19" CRT...you guys that need more are so extreme I can't understand you....I'm very happy with my 2.4C at 3.0 ghz processor on my 2 year old Abit IS7 motherboard with 1GB of Ram running a 6800 GT. There is absolutely no reason to upgrade any of my components at this time in my mind.
1600x1200 just isn't necessary and AA has always looked worse to me...looks blurry, AF looks good, but I don't require it to enjoy a game....
