Fastest scanner?
aNtHrAx323
A client's office is trying to go paperless, so I'm trying to find the fastest scanner on the market... The software (Dentrix) has built-in image management, non-OCR, so basically I need a scanner that can scan an 8.5" x 11" piece of paper as quickly as possible. Not many web sites list this type of information as a spec (all are related to OCR or photo scanning-to-email). Any tips? B&W/grayscale is the major concern as these are all medical documents, and again, speed is the most important factor. Any tips would be appreciated. Thanks!
Note: The goal is ~5 seconds per page or better if at all possible.
What your looking for is either a duplex or fastfeed scanner
My experience is with Xerox scanners (of the favor made 10 years ago!) so i cant vouch for any of these but here is some linkage at the egg anyway:
XEROX DocuMate 250
Convert documents into PDF files at 22 pages per minute
Holds up to 50 pages in Auto Document Feeder
http://www.newegg.com/Product/Product.asp?Item=N82E16838152004
XEROX DocuMate 510
Convert documents into PDF files at 10* pages per minute
Holds up to 50** pages in Auto Document Feeder
http://www.newegg.com/Product/Product.asp?Item=N82E16838152006
Fujitsu FI-5110C
Fast Color scanning up to 15 ppm / 30 ipm
Monochrome and greyscale capture up to 15 ppm / 30 ipm
(PPM = Pages Per Minute or Path Probability Method - whichever seems more logical at the time :p)
http://www.newegg.com/Product/Product.asp?Item=N82E16838115009
JCrow
