Stereophile
- Dec 4, 2003
Does ps 2.0 really look that much better ?
What is the difference ?
Originally posted by IYIENACE
I don't know who you are referring to, but all settings card AND game were at maximum including surround and my monitors max resolution.
I didn't go into the ini and alter anything. It's just like it would be if you D/L and installed it.
Originally posted by Albuquerque
Why is it that, of all the virtual badasses that have posted in here, only ONE OF YOU is playing with water settings on Ultra high? How can you tell? Look at the trees, grass, and smoke/fire/enemies in the water reflection... You can't see them in the reflection unless your water settings are on Ultra High.
Need an example? http://www.hyundaiproject.com/farcry/FarCry0007.jpg
See the trees? The truck? This is water on ULTRA high. If your rig is badass, then you need to enable thisYou also need to hit the console and do the "e_water_ocean_sun_reflection 1" for the proper sun glare effect off the water...
Next, why the HELL would you disable shadows if your rig is all that? Shadows are half the badass creepy part of this whole game. Need a demonstration? http://www.hyundaiproject.com/farcry/FarCry0003.jpg
It might be hard to see, but that's a bad dude floating in knee-deep water, with his shadow being cast onto the ground and being then further rippled by the turbulence in the water. Look at his creepy-ass fingers in the reflection! How could you live without that?
And finally for all these "uber badass" rigs, you need to start posting some r_displayinfo 1 screenshots... Having your game on "very high" would normally give you a screenshot something like this: http://www.hyundaiproject.com/farcry/FarCry0013.jpg
Yeah, six million polys per second, Bleh! You need to start tweakin a little, Very High just isn't enough!http://www.hyundaiproject.com/farcry/FarCry0012.jpg
Let's pump THIRTY MILLION polys outta this 9800! The difference? Very High (and Ultra High on the water) plus the following:
e_terrain_lod_ratio 1
e_vegetation_sprites_distance_ratio 2.5
r_bumpselfshadow 1
Make your rig cry! Make your eyes water from the beauty! And post some screenies of it all!
Originally posted by evilnickwong
My specs are as in my sig, I'm having all the settings at max, but texture detail at medium running at 1024x768 with no AA/AF.
I wanna play at 1280x1024, but it kinda lags at that res.
Why??![]()
Originally posted by emorphien
Poor programming.![]()
man, can't a smiley face give away a joke these days? oi
Originally posted by kronchev
sorry, too much anger![]()
Upgrading system RAM usually only speeds up loading times, does it affect the FPS in Far Cry as well?
Some locations are OK for me to get about 60-100 fps, but in some of the outdoor levels, I drop to 25-35 fps! ANd this is only at 1024x768 with about 5 million polys.
Is it just me or is my 9800 Pro feelin a lil slow?![]()
Originally posted by DRJ1014
about the memory... when u play with 512 you will experiance lag. when you play with 1 gig its smooth. the memory has just about everything to do with the game as the video card. if you where running 256 memory and a 9800xt you would experiance lag like no ever. the memory (256) isnt enough to support the game as well as the video card.
