1Wolf
- Jul 10, 2007
I'm looking to setup an H100 push/pull in an NZXT Switch 810 case. I was wondering if anyone had any recommendations for good fans that they feel would work well paired with the H100 fans for push/pull?
According to Corsair's website, the fans that the unit comes with are 120mm 46-92CFM & 1300-2600RPM.
I'm guessing that I should be looking for fans that match the CFM & RPM of the fans pre-installed on the H100 for them to pair up best (So that the fans are pulling and pushing the same amount of air at roughly the same RPM?).
The NZXT Switch 810 comes with 140mm NZXT fans. There are spots to mount 2 of them at the top of the case...should I just use those? Or am I better off getting a set of fans that would work better with the H100? Should I stick with 120mm's?
Thanks!
Thanks!
