Fanless video cards?
dgsg
Passively cooled with heat pipes and sinks. Good idea or more trouble than they are worth?
Is there a specific card you are referring to, or just in general? I don't think I'd trust a passive cooling solution on say an 8800gtx, or my X1950pro..... but I did have an old 9800pro that I passively cooled with a Thermalright V1 and it worked just fine, sooooo.... I guess it really depends on the application.
if you haven't yet, look in the HR-03 thermalright cooler..
very robust passive cooler, or with a minimal silent fan you can get some very good cooling..
only drawback (as with any passive system) is its size..
but i use i ton my X1900XTX and it keeps the card cooled well below the noisy stock solution (not to mention 100X's quieter)..
http://www.thermalright.com/a_page/main_product_hr03.htm
i have also installed this on a 7800GT and ran it passively with full load just fine..
7600GT or 7950GT
One of my daughters has the ASUS 7600GT that's passively cooled and she games.. no issues. We run almost ALL passively cooled Vid cards at work. I have the XFX 7950GT passive, it does great. I can't even hear my system at work. Have a friend that games with the same card heavily and is experiencing no issues.
Passive technology now days is quite good - any 7600GT or 7950 on the market now with passive cooling will do fine. H-street is right, passive cooling does take up a lot of room - so be prepared for that. I think it'll be a while before we see passive cooling for the 8800's, but I can see it coming.
QFT
As long as your case has decent air flow the passively cooled 7600GT/7950GT will run just fine :cool:
