Quite honestly, the 218+ is pretty quiet to start but if you want silence (and of course if your drives can deal with no airflow and higher than ambient temperatures) then just pull the fan connector and uncheck beep warning in the Hardware control panel so it doesn't bug you. If you want off-the-shelf/reliable/relatively $$$ efficient, and not QNAP's disasterous dealing with their ransomware situation I would stick with Synology.
Are you really sold on off the shelf because you don't want to build or are there specific Synology features you depend on?I like my Synology Diskstation DS218+, but I want a fanless NAS that I can use with SSD NAS drives. Is there any good off-the-shelf solution?
Even if your ssds dont need active cooling, there is the chipset/cpu that will need bigger passive heatsink for a totally fanless NAS, that you can likely can custom build, but since you mention you like synology, i would suggest to investigate on the fan noise on the Synology 6 bay 2.5" NAS DS620slim (Diskless).I like my Synology Diskstation DS218+, but I want a fanless NAS that I can use with SSD NAS drives. Is there any good off-the-shelf solution?
consider a simple dust filter on the intake. Even if you have to externally mount it, it will work fine.There is ZERO fan noise from my Synology. The issue is dust build up. It sucks in and builds up a tremendous amount of dust which requires periodic cleaning. I want a fanless solution.
My storage needs are minimal. I do zero media streaming from the NAS.
Ok, if you don't want to build your own, and if you are fine departing from the Synology DSM, take a look into QNAP HS-264-8G-US, its a 2bay fanless nas that has 2 sata ports. If you wish to see the interior checkThere is ZERO fan noise from my Synology. The issue is dust build up. It sucks in and builds up a tremendous amount of dust which requires periodic cleaning. I want a fanless solution.
