Ok, I have a total of 5 fans on my current pc (if I build I'll have more but just asking for advice right now)...
Ok, this is the case I have! Not the best pics but it'll help me describe. I have 3 120mm fans, 2 are normal to the case, one in the front and one just beside the CPU and above the gpu.
I then modded 3 fans, 2 90mm, and 1 120mm (what I had at my disposal). I have the 120mm setup on the lower part of the "comb window" feature on the case, blowing in 'colder' air closer to the floor, and I have the 2 90mm (which are pretty much directly infront of the cpu and gpu) blowing out. Does this setup seem proper, or should I set all the fans minus the highest fan to blow in?
Below is the report as shown from everest. Just wondering how they look to you all. This is IDLE!
Temperatures
CPU 41 °C (106 °F)
CPU #1 / Core #1 45 °C (113 °F)
CPU #1 / Core #2 46 °C (115 °F)
Chipset 44 °C (111 °F)
PWM 48 °C (118 °F)
GPU 54 °C (129 °F)
GPU Diode 59 °C (138 °F)
GPU Ambient 46 °C (115 °F)
Maxtor 6E040L0 25 °C (77 °F)
Cooling Fans
CPU 2083 RPM
System 1361 RPM
Chipset 3375 RPM
GPU 1425 RPM (60%)
Voltage Values
CPU Core 1.26 V
+3.3 V 3.25 V
+5 V 4.92 V
+12 V 11.90 V
+5 V Standby 4.97 V
VBAT Battery 3.04 V
GPU Vcc 3.27 V
PS, no I don't have any type of cover on my fans such as leg hosing or anything, I should as it gets dusty in there
! lol
Temperatures
CPU 41 °C (106 °F)
PWM 48 °C (118 °F)
GPU 54 °C (129 °F)
Cooling Fans
CPU 2083 RPM
System 1361 RPM
Chipset 3375 RPM
GPU 1425 RPM (60%)
Voltage Values
CPU Core 1.26 V
+3.3 V 3.25 V
+5 V 4.92 V
+12 V 11.90 V
+5 V Standby 4.97 V
VBAT Battery 3.04 V
GPU Vcc 3.27 V
