I've gotta replace atleast one fan(wont run at anything but high speed, an Antec tri cool).....and figured its probably as good of time as any to just replace the 5 stock Antec fans in my case.
I'm going to get a fan controller
this one- http://www.newegg.com/Product/Produ...s-_-na-_-na&AID=10521304&PID=3891137&SID=194r
and need to get 5 fans, trying to figure out which ones to get......trying to keep price at under $75 shipped(not sure if its $3 per fan on newegg, that would be pretty rediculous...) for all on newegg....Ill probably wait a week or two to order, but I figure fan prices are pretty stable(that controller has stayed at that price for a good two months)
i was thinking maybe doing one of these scyth's
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185056
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185057
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185059
or maybe this Xigmatek
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233035
i could care less about noise at high speed, at low speed I figure most fans will be near quite that it wont matter.....the primary purpose is cooling
any other ones? which of these would be the best option?(i'm assuming of the Scyth's the last one I linked, since its the same price as all the others, but moves more air...)
or
or
