I did a little searching about intake/exhaust, but i wanted an opinion directed towards me. I decided to get that 40$ w/ rebate case from frys, but didn't have intentions of using it at first, but then i ended up upgrading, and didn't want to use my old case since it was a piece of junk. Anyways, there is a front spot for an 80mm fan & a back spot for a 120mm fan, however there is also an air duct on the side of the case, but i planned on taking that off and adding another 80mm fan. Okay, so right now i have an e4400 w/ stock cooler, but planned on getting the Thermalright Ultra-120 Extreme w/ a yate loon 120mm, when i buy two 120mm(1 being the yate loon) & the two 80mm, so basically i want to know which fans would be better as intake and which as exhaust. Originally i was just going to make the front & back exhaust while the side be an intake... but i wasn't 100% sure.
here is a link to the case:
http://www.ultraproducts.com/product_details.php?cPath=13&pPath=250&productID=250
thanks in advance
thanks in advance
