Fan Help
fightingfi
Look at Me! I need the attention.
I know Noctua is teh best for fans but i dont want to spend 30 bucks per fan. what are the 2nd and 3rd best 140 mm fans to buy please thanks !
SticKx911
What are you putting them on? Just overall case fans, air towers or radiators?
pendragon1
can you not do any research for yourself? look at the page it tells you the db.
