Fan Controlling.
Maccco
I apologise if this is the wrong forum.
I was wondering, Are you able to control more than one fan per knob?
Say 6 fans on a 360mm rad, can they be controlled by the one knob, then the 4 fans on the 240mm rad on a second knob. So this way a 4 fan controller can be used per rad in my case?
Or will I need to buy more than one fan controller and have the fans per knob?
Yes, just make sure you get a quality fan controller. To give you a specific answer, you must tell us the model of the fans you're using.
I plan to buy a new set of fans when I watercool. But I was thinking of Xigmateks or CM Sickleflows? I am fully open to the sudgestions, even for the fan controller.
Almost all of Sunbeam's Rheobus controllers can handle 20 Watts on each channel, which should be enough for 4-5 fans. With better heatsinks, they could handle more too
