Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Click on the configure button, open up the fans tab then look for a rpm readout under "sample", you want to tick all the boxes that have a readout. Once you've done that you should be able to adjust the fan speed.
