False CPU temperature reading?
Zakal
I recently replaced an Asus P5Q SE Plus mother board with another refurbished identical one. After this the computer is giving an overheating warning when it is restarted and the CPU temperature is reading at around 100c. However, the computer is not having any lock-up problems. The heat sink seems to be firmly attached, (all 4 posts are clicked in and look secure,) and the fan is running fine at about 2000 rpm. The fan and the heat sink are clean.
I am a bit of a hardware amateur but a more knowledgeable friend has told me that it is very unlikely that the machine would not lock up while the temperature is that high and thinks that it may be a false reading. Has anyone had a similar experience with this issue? Also, is there a way to verify the true CPU temperature when the bios reading is questionable?
Thanks in advance for any advice or opinions.
Sure, if you have an OS loaded. Download and run RealTemp. Most of us use it to check cpu core temp.
http://www.techpowerup.com/downloads/1691/Real_Temp_3.40.html
I tend to agree, for a core 2 Duo chip 100C is right on the edge of "I am too hot" and a few deg above that it will shut down to save itself. So if you ran anything at all that loaded the cpu (game) I would expect it to have all kind of problems.
I had this problem with an Abit IP35-e a while back. The BIOS temp for the E8500 would report as 98*C. The actual temp as reported by Core Temp was significantly less. I actually had to turn off temp monitoring in the bios for Windows to load initially. The system ran great once I did that.
My last Asus board (Rampage Formula) reported temps that were 15C lower than they actually were (in the bios and asus pc probe). I just uninstalled all the asus monitoring and optimization "crap" and use core temp and real temp.
