Modred189
Can't Read the OP
- May 24, 2006
I eliminate rooms I no longer need ... the older resource rooms were destroyed a long time back to make room for the ability rooms (I do keep one Greenhouse and Water Purification plant for the storage capacity though) ... I have just started culling the ability rooms (to reduce my power consumption) that I don't need any more ... unfortunately I am stuck with my living quarters wherever I built them (since with 200 population I can't destroy any) but all other rooms will get destroyed and moved around as needed as I gradually max out more dwellers ... since I am starting to send out the hoards into the Wasteland again I will likely be building more Med bays (for Stim storage) and more store rooms (for weapon and outfit storage so I can sell off what I don't need) ... if my folks can find some good stuff I will start the elimination of 6 damage weapons next (I have purged all weapons with 5 minimum or less damage now)
I can't figure out how to eliminate rooms. I try and no matter what the room is or its configuration, it says it can't be deleted because it's connected to two rooms.
EDIT: I take it back, it appears a patch fixed the issue at some point. Alas, I may have designed myself into corners making elimination of rooms very difficult.
