Falcon-NW - Tiki
Does anyone know what PCIE revision the riser card is for this unit? I can only find PCIE1 risers online, might be crippling that graphics card.
I wonder how the size compares to the Alienware X51.
X51 is 13.5" x 12.5" x 3.74"
Tiki is 13" x 13" x 4"
So pretty close. It's worth noting that the X51 uses an external power adapter (up to 330W), while the Tiki can take an internal SFX PSU (450W).
Alienware X51: 10.3422858 liters
Falcon NW Tiki: 11.0776553 liters
Its only let down by a weak PSU. The tiki at least can fit an SFX PSU.
Yeah -- that's what I was thinking... you could fit a beefier vid card into that form factor (I REALLY like what he's done with a riser card for that vid, btw... i've been searching for that size card for a while) if you had the power overhead. SFX should be plenty as long as you're not a nutjob (like me) trying to fit a dual gpu into a ~10L case.
ahhhhh, i hadn't even noticed that there was no psu inside the case. that's is definitely a bit of a let down.
i think this is the purest in form itx case i've seen to date though. i think the real solution would be to get a riser card/pcie cable and custom a case from the ground up around this idea, the usage of space is just too good this way.
now if only i had some gear and a workshop to use.
At the rate things are going, this should be able to accommodate a dual GPU in 3 or 4 more GPU iterations!
my cousin bought a NW and parted it and put everything a HAF case, so i asked to use it and i absolutly love it for my fiance's computer... all she plays is WoW and minecraft.
Gets real hot though
