may i be worthy
[H]ard|DCer of the Month - December 2010
- Aug 17, 2010
http://foldingforum.org/viewtopic.php?f=67&t=18034
Looks like Langouste might be obsolete:
http://foldingforum.org/viewtopic.php?f=67&t=18043
Heh first bug is that it ignores the unchecked autostart! It grabbed a unit right away.
Just a few FAQ for those who want to right jump in
by bruce » Tue Mar 29, 2011 11:59 am
I just want to hilight a few common questions that a lot of people will have:
This is a new client, not new FahCores. With the exception of FahCore_16, you'll still get assignments of the same projects and will earn exactly the same PPD.
FAHViewer only works with FahCores which produce a current.xyz file, so for most people it will show a demo protein.
Third party monitoring programs such as HFM and FahMon and FCI have not yet been updated to work with V7.
If you configure a Windows service in Win7/Vista, GPUs cannot fold. (Limitation by Microsoft).
New WUs will be downloaded not long before the current WU finishes; That WU will start processing while the previous results are being uploaded.
A "slot" is a new concept probably best defined by an example. If you have been running several V6 clients on a single OS, you will now be running one FAHClient with several slots.
You will probably never use a command-line parameters. With FAHControl, you can change your configuration as needed.
The more complex your installation, the more you'll need to read the documentation.
