Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm running the console verson 5.04 on a P4 3.0 ghz with 1gig ram and the cpu only goes to 50 percent while the machine has hyperthreading so I'm not sure if that makes a difference. Any ideas why it dont use 100 CPU? thanks Guys
Actually, in my testing I have found that when you run 2 clients with hyperthreading and both work units use SSE it actually slows both down to the point where you get less PPD.
Generally speaking, it's better to run a single client on hyperthreaded systems. I'm a points whore and I only run one instance on my hyperthreaded P4 at work.
Thanks for the quick reply guys, I only got a p4 folding now but when I get to build my new quad core it will be folding in 30 days time. Cheers everyone
