F@H Stats not getting recorded
I see what you mean. Stanford says you have turned in one WU, but the stats site does not have you listed yet.
Give it another 12 hours and then you will be able to see your stats in detail, as well as grab yourself a badge.
p.s.
Welcome to the Team!
Team #33 For the Win! Fold on For the Cure!
Look in your FAHlog.txt file.
From that you should see how many work-units you have compleated.
From one of my SMP clients ...............
[12:09:14] Completed 500000 out of 500000 steps (100 percent)
[12:09:14] Writing final coordinates.
[12:09:14] Past main M.D. loop
[12:09:14] Will end MPI now
...............snip..................................
[12:10:20] - Shutting down core
[12:12:20]
[12:12:20] Folding@home Core Shutdown: FINISHED_UNIT
[12:12:26] CoreStatus = 64 (100)
[12:12:26] Unit 2 finished with 78 percent of time to deadline remaining.
[12:12:26] Updated performance fraction: 0.779821
[12:12:26] Sending work to server
[12:12:26] + Attempting to send results
[12:14:47] + Results successfully sent
[12:14:47] Thank you for your contribution to Folding@Home.
[12:14:47] + Number of Units Completed: 99 <- thats the line that tells you how many work unit you have finished.
What are you folding on and for how long each day ??
Luck ............. :D
I'm folding on my gaming rig when it's on and i'm not gaming.
As for the stats, thanks.
When i'm eligible how do I get the badge?
Well the next [H]ardfolding stats update is in a few mins, so you could well be on this one as your on Stanfords main server now.
If not try again in 3 hours.
Here is how you put your badge in:
Type {URL=http://www.hardfolding.com?go=38&id=620315}{IMG}http://www.hardfolding.com/ftag1.php/mem/620315.png{/IMG}{/URL}
Replace "{" with "[" and "}" with "]"
It should come up like this:
Ahh so I assume that the color is ranking? Nvm, I saw you can pick the color.
Also, where do I insert the badge to? My sig?
You can choose your own color, the color of the [H] changes as you complete more work.
And you copy and paste the link into the bottom of your post, not your sig.
Oh.... and I forgot, Welcome! Glad to have you folding with us:)
Color is chosen by the team member. The only thing that can't be selected for color are the [H] symbols which actually do refer to point standings. Copy the link from the site and paste at the end of your every post. It will appear.
There's also a way to bookmark it so that it automatically pastes the badge at the end of your post, but it doesn't always wok perfectly (for me) and not all browsers are fully compatible. YMMV.
So there's no way to keep it in your posts unless you Copy and paste?
Precisely. The bookmark method does the pasting for you but like I mentioned, it's not always successful for everyone.
How do I do the bookmarking method? I have the java but i'm not sure where to put it.
Thanks.
javascript:document.vbform.message.value=document.vbform.message.value + '\n\n'; document.vbform.submit(); halt;
That's what i get when I drag and drop it from my bookmarks.
^ Actually, all you have to do is click on the bookmark and it will automatically insert itself. No need for dragging.
My states are being recorded... they are just so darn low, might as well be 0 :(
But, any folding is good folding! right!
Thats right! Every WU sent back to Stanford is progress. Keep up the good work.
I'll put it this way, I sure as hell didn't get the points I have just overnight. I've been doing this since around 2003 or so. There have been way too many sober times between then and now to remember exactly.
Something is up with the HardFolding page... I have 0 points for yesterday although I know I did something like 26k...
