F@H directory is 1.1GB?
mcryptic
My folding at home directory is 1.1GB, and has over 200 .pdb files, Is this normal? I don't think the client needs to have all those files so can i delete them?
Crashsector
That definately doesn't sound normal. I don't have anything with a .pdb in my FAH directory. Sounds like it could be the work of a virus or something?
Anyone else?
KodiakStar
/'s by 0
168mb here
the pdb's look to be the files that f@h creates at every timed checkpoint save :)
apHytHiaTe
Maybe you stashed all your pr0n in there to hide it from yo mamma :p
The first thought that came to mind in seriousness was "trojan". "Virus" could also pop in there. "Driveby Drag'n'drop incident" sounds good too.
KodiakStar
/'s by 0
"step6459.pdb"
considering there is the word step in there.. I think it should be ok ;)
ie step xxx out of xxx completed
SmokeRngs
[H]ard|DCer of the Month - April 2008
My folding directory is sitting at 210 meg right now. I would just leave the files alone. It's probably just the checkpoint information as someone else mentioned. Just make sure the files disappear when you start a new work unit. I'd bet they will when that happens. Then new ones will be put there. If you don't like the disk space it's taking up, then I would suggest setting the checkpoint to a larger interval.
