Eyefinity upgrade
sfam198
Gaming (WoW mostly....I also like to play Diablo III, Skyrim, GW2, and various CoD games on occasion)
I'd like to keep it under $400 total
NJ, US, near Philadelphia
Video card, I don't think I'll need anything else but I may be missing something in order to support the new card. See current rig below.
Current rig:
  • Case: Corsair 400R
  • Motherboard: MSI Z77A-G45
  • PSU: Corsair HX750
  • RAM: Corsair XMS3 8GB DDR3 1333
  • SSD: Crucial M4 128GB
  • CPU: Intel i5 2500 (non-K)
6) Will you be overclocking?
No
3150x1680 (vertical) or 5040x1050 (horizontal) (3x22")
This weekend
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Don't need one
Yes, Windows 7 Pro x64
I'm pretty sure all I really need is a video card (or 2). I'm undecided on ATI vs NVIDIA, from what I've been reading Eyefinity is better than NVIDIA Surround at this point so I'm leaning toward ATI. Some input on that would be helpful.
Moved to Video Card subforum. You should get more up-to-date advice here.
GTX 670 would be the best bet at your price point or a stock 7970 but considering ease of use with DVI etc id go NVIDIA with the GTX 670 at $400 its a good option.
from what i remember AMD / ATi has issues with multimonitor screen tearing although that may have been fixed recently.
that said if you plan to go multimonitor and your planning on AMD go with an HD 7970 cheapest you can find and do some software overclocking.
