Dr.GumbyM.D.
- Oct 18, 2010
Hi all
Are there any guides to setting up Eyefinity, step by step? Even AMD's pdf guide gives the most bare of directions.
Specifically the problem I'm having is that my 3 monitors are all recognized, however CCC only allows me to run 2 at a time, with extending or duplicating the third forcing the replacement of another screen. I've tried every which combination I could think of to get it working. 2 of the 3 monitors are 1080p, the third supporting higher resolution, but being a smaller screen, if that makes any difference. I want them all to run 1080p.
I bought mDP->DVI adapters from MonoPrice, but now I'm finding out that they're not active adapters (GRRR!!, they didn't add that to the item until recently, and you've got to dig through to find the answer). Is that the problem I'm having, even with 1080p monitors? I've been using dual-monitors through the adapters for months now with no problems.
The second issue I'm having is that before trying eyefinity, I upgraded to 11.3. That was a bad idea, because now I don't know if this/these problems stem from that or not. 11.2 ran perfectly. The second issue is that whatever monitor I add as a secondary now ALWAYS is garbled/pixelated. I've never had that happen before. I moved both monitors to DVI and DVI, HDMI and DVI, DP adapter to DVI and DVI, both on mDP, everything, and it's still always showing the second monitor pixelated. I've never had this problem before I installed 11.3 or tried eyefinity. Where am I going wrong?! (From some of the 11.4 comments, it sounds like people have been having this same problem when trying to set up an eyefinity group, though I haven't even been able to get that far...)
I'm downloading 11.4 preview now, but my internet connection is slow as crap, so I'm hoping I can get help before I even bother reinstalling drivers.
If I can't figure this out, I guess I'll uninstall, driversweep, and go back to 11.2.
Thanks in advance for your assistance!
