Single big quality monitor still wins the day for me. I decided the monitor bezels ruined the effect back in the Matrox Parhelia days.
Here you go!
Single 43" NEC wrap around monitor - no bezzels 4 seamless panels with a resolution of 2,880 by 900. 12 bit color spectrum and .02 ms response.
http://www.coolest-gadgets.com/20090604/nec-crv43-monitor/
If it wasn't priced to the moon I'd definately be interested in one of those
1 x 30" @2560*1600 (landscapte) + 2 x 20" @ 1600*1200 (portrait) seem to be the best of both world... Who agrees?
3x24" Eyefinity has a much higher resolution (3600x1920) than a 30" (2560x1600) or a TV (1920x1080). It's just not the same kind of experience.Yes, but eyefinity without bigger FOV is useless. Why have 3 monitors pivoted when you can have one 30 inch monitor? Bigger screen than 30 inch really isn't the goal of eyefinity for gaming. For that purpose I use my LCD TV, capable of 1920x1080 at 100Hz, perfectly enough for gaming with same FOV as my 17 inch monitor. The main thing is that it's a much better experience while gaming on 3 17inch CRTs, so I assume that it is much better and greater experience with 2 23inch LCD monitors. Also, bezel is no problem, I don't even notice it after a few minutes of playing.
3x24" portrait works for me, but really it all depends on the application or workload you use it..
The Source games particularly need a central UI.
If we really want to get technical those aspect ratios are actually 15:8, 16:10, and 16:9 respectively. But yes, they're all relatively close to typical "widescreen".There is no great difference between those resolutions in aspect ratio, just in pixel-count. Ratios are these: 1,875 1,6 1,777777778, so close that I think that they are the same thing 16:9.
Not enough desk space for landscape...soooo portait!
