Eyefinity on three different monitors via Tri-Fire
Dark Shade
I've done numerous Google searches and haven't come up with a fix for my issue. I have three monitors, each one attached to a DVI connection on each of my 5850's (identical video cards, in each PCI-E slot). When I go into CCC and click on the black triangle, I only have options for Disable, Rotate, Identify All and Identify, no "Create Group". Do I need all of these monitors hooked up to one GPU or something, or is something wrong with my setup? The cards are connected with Crossfire bridges, 1-2 2-3.
Another issue is that they are three different size monitors, two are 19" max res. 1280x1024, and the center is a 24" 1920x1080 monitor. The two 19" are also different brands (Samsung and LG).
You are doing a number of things wrong.
1) You have to have all three monitors hooked up to the same card.
2) The monitors can only use the highest common resolution on all three monitors in a display group, meaning you could only run 1280x1024x3.
Your setup really isn't going to work, man. You can't use two 4:3 screens with a 16:9 screen at different resolutions. Sell your two cheaper monitors and get two more identical 1920x1080 panels.
Softth may work in getting it all together in one group, but I don't think crossfire works with that.
Unfortunately they don't make my monitor anymore (Acer P235H) and new monitors aren't in the budget, so I'll either deal with single monitor gaming or playing at 1280x1024x3
All you need are 2 more 1080p monitors, the size and brand does not matter.
