Eyefinity on just two monitors?
IIRC, Eyefinity works on 2-6 monitors. I've done Eyefinity on two monitors before, however, the bezel down the middle was annoying.
Yup, but it makes almost everything unplayable since the critical screen "information" is almost always in the exact center. Of course, the "center" is either missing (if you correct for bezels), or annoyingly split between two screens about an inch (if you're lucky) apart.
It can be done, but really only useful if you're trying to do the very limited amount of split screen games on pc or using emulators for splitscreen, or playing burnout paradise (it has a mode for 2 monitors that renders the center on one monitor and extends left or right).
