What is the issue with 60hz?
To me, nothing. It works fine. Some people simply cannot use a 60hz monitor, though.
No, you're definitely not going to get around 60 FPS with three 19x12 monitors on a single 5870 unless you really dial down some settings. Not sure that even 22" will do the job at max settings, but it'll bring you a lot coser to the goal with high settings.
