Hi,
I have two HDMI 1.3 (10-bit color supported) displays.
I am considering getting an Eyefinity card but I'd like to know if Eyefinity supports this configuration:
* 10-bit color to each display (30-bit in total instead of 24-bit). I understand that the control panel says 32-bit color support however I am not sure if this is 8-bit x RGBA or it can be set to higher bit depth; especially for HDMI 1.3 and Displayport outputs.
* If the 10-bit is supported, would a Displayport to HDMI 1.3 pass the 10-bit color (RGB) to the HDMI display (I understand there is no dual HDMI version of Eyefinity out there).
Thanks - Andres
Thanks - Andres
