What about single monitor 3d on an AMD card? All that i have seen, 3D wise is based on Nvidia products. What kind of monitors, hardware, and glasses are called for if using an AMD solution?
Edit: dur. answering my own question.
http://www.amd.com/us/products/technologies/amd-hd3d/Pages/hd3d.aspx
i;d rather they get eyefinity synchronized when having to use 2 display ports and 1 dvi port since display port hubs dont exist.
In regards to NVIDIA - those fellas need to get on the DP bandwagon. The monitors I have support HDMI or DP, not DVI. This would likely be because VESA has killed the DVI spec and there will be no more updates to the platform. I RMAd my new 560ti because NVIDIA drivers either wouldn't recognize the card or completely broke DP support. This turned out to be a known issue with their drivers as of mid January. I had every intention on going green this cycle but NVIDIA doesn't seem to be able to get their act together in regards to driver support any better than AMD excepting that the AMD cards I bought actually would work with DP (albeit only 2).
No, this was a specific issue with the drivers as confirmed by EVGA support. When connecting via DP, the card would output video until you loaded drivers, indicating that the card, cable, and monitor were all working over DP (at low resolutions anyway). It wasn't until you loaded the drivers that the DP output would fail. The 560ti isn't supported in the 280.x series of drivers as it was released after those drivers, and the 290.x drivers broke DP compatibility with this monitor. So I could either get an NVIDIA driver which would support my card, or one which would support my monitor, but not both. This might have changed since mid January (as I stated above), but the issue was confirmed which was why I RMAd the card.Really? You just said your screens can use HDMI or DP, you could have simply used a DVI to HDMI cable/adapter since they're the same video signal . As far as recognizing the card, either A) PEBKAC, or B) defective card.
Nope, Crossfire requires all connections to come from one card. If somebody ever gets around to releasing an DP 1.2 MST hub then I could use that as well, but that's been delayed so many times that I won't be holding my breath.in crossfire you can't just use 2 DP on one card and the third off the second card?
